dynoed my new set up
Old Oct 12, 2005 | 03:19 PM
speedcrazy's Avatar
240rwhp/295rwtq SAE - this is stock with CAI
324rwhp/348rwtq SAE with the mods in sig. Spark retard and hp still climbing at 5800rpm when I let off.
a few pulls i thought the car was acting weird cause it wasn't pulling and wouldn't accelerate at all like i had no power.
after i was done the session i found out the dyno operator had a wire going really close to the throttle cable and it was actually binding it up sometimes. thats why some of those pulls were crap.
i figure when i get the spark retard stuff figured out and if i would have pulled to 6200rpm or so i would have seen more hp. my goal was to get 350rwhp/350rwtq SAE with my set up and i think i can still get that.
Old Oct 12, 2005 | 03:37 PM
Jameslt1TA's Avatar
Re: dynoed my new set up
YOu've got a nice gain from stock but not near as close as most have seen with heads/cam. What kind of springs are you running? Also what kind of stall?
Old Oct 12, 2005 | 05:09 PM
vin1382's Avatar
Hmm, i almost made that with the 224/230 cam only. somethings definatly going on. My power peaked around 5800-6000 rpms..so i dont think running it to 6200 would gain you much more peak hp.
whats the word on those GTP heads? what do they flow like?
Old Oct 12, 2005 | 06:06 PM
jkipp84's Avatar
I got 324/318 SAE with the cc503 on stock heads/pcmforless tune... Since you've got ported heads, I'm betting there's a good bit of power to be found yet.
Old Oct 13, 2005 | 08:56 AM
RealQuick's Avatar
Nice gain over stock for sure! Get the KR taken care of.
Old Oct 13, 2005 | 09:28 AM
Honda Hunter's Avatar
You could add some race fuel to see if it's false knock. How much KR were you seeing?
Old Oct 13, 2005 | 10:18 AM
roadtrip120's Avatar
I realize that eveyones car is different, you may not have all of the supporting mods, bolt-on's ,exct..
What was your A/F and WOT timing???
Not to dog, but just to say its common for a hotcam or a 224/230 to put down 330rwhp ish. Heads should help out more.
My 1994 Z-28 --327rwhp 350rwtq , stock cam. Everyones car is different but it should have put down a little more, check into your problems
Old Oct 13, 2005 | 10:29 AM
RealQuick's Avatar
How are the comp r's adjusted? Your power will suffer if those are too tight.
Old Oct 13, 2005 | 01:22 PM
truedualws6's Avatar
Your goal is very realistic. I think you are leaving 25-35 rwhp on the table
until everything is dialed in. You will get there.
HarleyZ28
Oct 5, 2015 06:23 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
FredM
Mar 6, 2015 03:04 PM
Jlo
Feb 3, 2015 09:41 PM
