Dyno'd my car over the weekend
No...I have a 97 M6 Transam and 4th gear is 1:1 meaning the input and output shaft on the tranny are rotating at the same RPM pretty standard I believe for a dyno pull.
My tach also reads 1000 at idle but datamaster displays 800 which is right.
Kris
Kris
Yes, 4th on the 6 speed T-56 tranny is the 1:1 gear. It doesn't matter what your tach read, because they get the rpm directly off of the engine by hooking up a probe to one of the spark plug wires.
Do you have the air to fuel ratio (a/f) on the dyno sheet? That would help a LOT. My bet is that you are running pretty rich.
Also, do you hear any header leaks? (pfft, pfft sound on hard acceleration)
You should also check for arcing wires. It's easiest to see when it's dark out. Start the car and let it idle. Look for any sparks between your spark plug wires and other objects.
Do you have the SES light on, with any codes?
Fuel filter?
Dan
Fuel filter?
Dan
I'm in agreement with others, I think your numbers are way low. I'd have a close look at your air/fuel numbers, if you havent already. Just for reference, my 95 6 speed, mid lengths, high flow cat, borla, CAI did numbers in sig
Now this has got me kinda scared. I'm gonna be going to a dyno day on the 12th with a group of guys off Stangnet. I've been having ignition probs, that I think I've pretty much traced down to failing opti.
I'm afraid I'm gonna get up there and put down something like 190hp and give LT1's a bad name in front of the competition.
Originally posted by jer4251
and i always get a code saying my MAF is malfunctioning. i dont know how to fix it.
I used the mustang dyno also, 40 bucks for 3 runs. no A/F.
I think my problem lies in the a/f ratio and my MAF. I put the origional ends back on but i still get the same code. its somewhere in the wiring and not the actual MAF.
Mustang Dyno numbers are lower than other kinds... Im not sure by how much though. Sounds like your porblem is MAF related especially if you have a code.
it may not be working at all..I think the car has a "limp" mode for a MAF error.
Dec 1, 2014 08:08 AM
