DYNO tune help
Old Jun 17, 2011 | 05:45 PM
Black 97 SS's Avatar
DYNO tune help
I took my car to Motor City Speed for a dyno tune. I ran into a few issues with the car.
Two cylinders 1 and 4 are not fireing at low RPM and another cylinder is weak.
The pipes are not even getting hot. I have no SES light.
I think it may be a optispark issue. It is a vented MSD unit with about 15000-20000 miles on it.
The Dyno is not showing a miss up top and has not rolled over even at 6700 RPM, but the numbers are not good.
350 WHP and 315 WTQ, on a mustang dyno.
We are also hearing a noise in the front of the motor that is Intermittent, a scope is suggesting the Opti or under the timing cover.
Old Jun 18, 2011 | 03:23 PM
Re: DYNO tune help
So i have an update,
The miss was be caused by 2 injectors not being seated.
The noise is still in the front of the motor and the opti spark has a strong spark.
The noise gets better with the accessory belt off. All things spin freely. Im thinking the balancer is not seated against the crank key since i can keep tighting it past where it should be. Im going to buy an ATI super dampner and check the key.
Old Jun 20, 2011 | 06:39 AM
GreenZLT1's Avatar
Re: DYNO tune help
Are you still taking her to Ignace this weekend?
Old Jun 20, 2011 | 03:19 PM
Re: DYNO tune help
Heck yea i am, even if i have to hook my John Deere too it.
RallyRed701/2
Jul 27, 2015 02:55 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Strick
Jul 14, 2015 07:28 AM
mrwz28
Jul 8, 2015 09:11 PM
