Dyno Run/ Turd Alert
Old Dec 27, 2005 | 03:37 PM
  #16
wrd1972's Avatar
Re: Dyno Run/ Turd Alert
Originally Posted by Dfetter84
i had the engine hot
bump it over...watch the lifters close+open and
find 0 lash
tighten 1/2 turn, tight poly lock
12.3 compression after all is done
dont sure what base timing is or what the a/f ratio is
Thats the way I set mine and im sure they are dead on.
Old Dec 27, 2005 | 04:41 PM
  #17
93black-ta's Avatar
my comp r's dont like anything past 0-1/8 lash.
Old Dec 27, 2005 | 07:18 PM
  #18
LTOne4Fun's Avatar
First the car on the dyno on a few pulls, around 5300 rpm it picked up instantly about 50-60 hp/lbs of torque. If the rockers are too tight, I dont see it picking up a ton of power out of nowhere like that, well go thru the rockers again though.
These are Comp 850-16 lifters OEM valved, need around .050-.060" preload. on a 7/16 stud (I think its 7/16-20 thread pitch correct?) one turn should be about .050" then.
Old Jan 19, 2006 | 08:14 AM
  #19
Dfetter84's Avatar
i have the dyno sheets now
email if you wanna see what we are talking about
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
