Dyno Run:Had a Problem.
Old Jun 4, 2006 | 09:10 PM
Black_Z28's Avatar
Well, I got on the dyno this past weekend. Some details about my car...it's a 96 camaro Z28 with full exhaust(TPIS mid-lengths and a flowmaster catback), ported heads which flow in the mid 270s, and a cam which is the TPIS ZZ409. And I had the computer tuned by Madwolf, but I think he messed up a little bit on the tune. And you'll see that when you look at the dyno graph.
Anyways, it cut out really bad up top when it was getting really fat/rich. Do you guy think that it cutout because it was running so rich? Maybe the spark arced? The opti only has 50K on it, and the car runs just run at idle and everywhere else in the RPM but up top, and I just replaced the coil with a MSD coil about 50 miles ago. The spark plugs where replaced last June when I put heads on the car was well. And the wires all appear to be in good shape. I couldn't find anything wrong with the wires.
Anyways, here are the pictures of the dyno.
I emailed Ion to see if he could help me out and retune my car, so it isn't running so rich. Because running 10:1 is pretty bad. I'm hoping that the car is just getting too much fuel, but any other ideas would be great.
I know the car has a ton more power left in it, because a buddy of mine with almost the same setup put down 370rwhp the very same day.
Thanks.
Old Jun 4, 2006 | 11:35 PM
String's Avatar
Re: Dyno Run:Had a Problem.
That rich might be fouling the plugs. Have you pulled them and checked? You definitely need to lean it out. You will probably pick up 20-30 hp by leaning it out. You might also have a problem in your ignition tables. Have them checked and fixed if necessary.
Old Jun 5, 2006 | 12:50 AM
OrbitalChris's Avatar
yeh--and get a different cam those tpis dont live up to the hype
Old Jun 5, 2006 | 12:16 PM
Black_Z28's Avatar
Umm, ok. What are you talking about....all the hype? They say 435 crank HP on a heads and ZZ409 car, and that's exactly what it made for a buddy of mine. Mine will make almost the same once I get it tuned correctly.
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
