Dyno results, LE heads and small Joe O. cam
Old May 29, 2005 | 10:55 AM
  #16
Jeff95TA's Avatar
Re: Dyno results, LE heads and small Joe O. cam
Originally Posted by 80TA
Be very curious to see what times you run Jeff 95ta since your mods are also virtually identical to my final planned mods. You have no times with your current configuration?
Hope to make it to the track on Tue.
Old May 30, 2005 | 04:41 AM
  #17
1982z28with18s's Avatar
My cam is a ~220/226 under .550 lift, I'm sure the cam is similiar but not the exact same as my cam. Baby cams can run good though, see my sig for times in horrible weather. My old setup just put down 385rwhp/368rwtq on a STOCK tune in a 6 speed car also all on the stock bottom end still.
Old May 30, 2005 | 08:48 AM
  #18
NightTrain66's Avatar
pretty good #'s.
I am glad the car is back together.
Lloyd
Old May 30, 2005 | 09:57 AM
  #19
80TA's Avatar
Sorry to ask this again but do you have LE1 or LE2 heads?
Old May 30, 2005 | 12:05 PM
  #20
Z-RATED94's Avatar
1982z28with18s, same here with the lift. Almost spot on with the duration. But I'm guessing a little more LSA than what yours had. Reason being, Joe was told this car might have to pass the sniffer test.
80TA, the heads were done before LE started using stages. They do have the 2.00 1.57 Ferrera valves, with 195cc intake ports. I have the flow sheet laying around somewhere if you would like the flow #'s.
Jeff95TA, yes, dynos and flow benchs do vary. Maybe it was a happy dyno, maybe not. The #'s are SAE , for those of you that were wondering.
LT1Squirrel, the bottom end is stock with 28k on it. Not sure were it peaked at rpm wise. The graph used mph instead of rpm. HP peaked at 114 mph if that means anything to someone.
jchevy, the AF starts off at 12.5 and finishes at about 13 to 1.
Old May 30, 2005 | 02:00 PM
  #21
LT1Squirrel's Avatar
if you have similarly stock sized tires you would peak at ~5500, sounds good on the stock bottom end to me
Old May 30, 2005 | 02:33 PM
  #22
madwolf's Avatar
From my experience, Joe O cams don't always dyno real high, but they sure kick some butt on the track. I bet you'll be happily surprised with better than you expected times when you take it to the track.
Old Jun 1, 2005 | 09:49 PM
  #23
kmook's Avatar
Advanced Tech Moderator
I'm glad you got it all done!
Old Jun 1, 2005 | 09:56 PM
  #24
Z-RATED94's Avatar
Thanks Ken. Who knows, maybe if Jim at Speed can find me a few more HP with the new fuel pump and that intake manifold goes on, close to 400 rwhp might not be out of the question. One can only hope.
Old Jun 1, 2005 | 09:57 PM
  #25
TransAm396's Avatar
yeah thats if you can get ahold of him without him ignoring you
Old Jun 1, 2005 | 10:01 PM
  #26
Z-RATED94's Avatar
He's not one of the easiest people to get a hold of. But then again some people have a lot more going on than others.
Old Jun 1, 2005 | 10:04 PM
  #27
TransAm396's Avatar
yeah but...he purposely did it...it was very upsetting..i heard alot about him..and was happy to have him help me then he kinda just put me off...i would of rather him at least let me know he was too busy..he even deleted my simple questions off of his board..so..i gave up on him
Old Jun 1, 2005 | 10:11 PM
  #28
Heatmaker's Avatar
Advanced Member
He's a busy guy, but a good one. We spent a good half our or so on the phone talking about what kind of cam he could design for my intended setup. Seemed to be a truthful and honest guy. Got my stuff pretty quickly. But he was hard to get a hold of. For some reason I was always able to catch him between 11:00am-12:00pm.
Old Jun 2, 2005 | 10:43 AM
  #29
Quickshotkimber's Avatar
Were you the guy that asked about the time to get a motor built? Then griped about him not responding quickly enough? You guys need to understand something. He owns and runs his own buisness and it has nothing to do with cars. He must get 100 calls a day from people that just want to chat or ask stupid questions. He does the car stuff on the side because he enjoys the sport and likes to make people go fast. SEE SIG!
Old Jun 2, 2005 | 10:50 AM
  #30
Some of them even dyno high, 428RWHP , and perform at the track. I ran mid 11s in 90 degree weather with a cam just a hair bigger than that one. The heads were ported by Eric Bradby, the same guy that ported Joe's, for the same price that LE charges. Coincidence? I think not
