Dyno results with hot cam
Well i just got my car back from Speed Inc. and I put down 329.8rwhp and 345.4rwtq. I have to say that I am very happy with the results and i cant wait to see what i dyno at with my 75 shot too.
Re: Dyno results with hot cam
yeah thanks guys! I've heard of hot cams giving like 25-30 hp but i gained 37hp and it was bout 90 degrees out and humity was bout 100% very muggy day and not ideal conditions to dyno in. The shop manager told me that i could have easily gotten another few hp in good weather
Those looks nice, but my friend dynoed 350lbs of torque with basically and full exhaust... 310/350 were his numbers... I guess he really got lucky with his motor.
thanks....oh and for the cut-out, no need for one. Im just either gonna run open headers like i did for a while when i first put them on, or i might go w/ dual electric cutouts right after the headers. Well its not a daily driver anymore so open headers wouldnt be that bad
I put down 340ish in my TH350/3500 set up. TQ was 420+ but that is b/c of the stall.
Getting the AFR dead on helps alot and spraying this cam is nice!! You will like the track results!
Nice #'s. I did 337/340 through my full exhaust, SLP shorties/y pipe, ORP, Borla. The exhaust was a little restrictive on that run, I had a 3" sound diffuser cone at the end of my ORP and the smallest opening plate in the Borla. Then I opened up the cutout (in my ORP) and made 355/350.
I think the hotcam is perfect for stock heads.
OK, why is my purple pearl car a SLUG??? 345/360 at the ground WITH ported heads. Granted it's still on a stock TB, but dang, I really expected to see more out of it.
Those are good numbers!!
Those guys are SpeedInc are awesome people.
My car dyno 345.3rwhp with the XE230/236 cam
Now is time to take to the track.
Let me know if you wanna come along with me.
Carl
Carl
I would like to also add that I picked up 3 tenths (12.6 to 12.3) with a gear swap and nothing on the 60'. I went from 3.23 to 3.73, the more RPM up top really helped, I would like to try some 4.11s!! I think that might help some too.
Originally Posted by gamecockfan04
^ Have you tried some PCM programming? If not you could probably release quite a few higher #'s.
Originally Posted by Shon Herron
Weight and good air is what makes mine go. I honestly do not think the TB is holding it back that much unless you got alot of head work. What is the MPH? I have run as low as 106 and high as 112, just depends on the track and weather.
One thing about the car is it's a 93 and was an A4 stock with a 3.23. Before purchase by me, a 95 T-56 was swapped in, so obviously the car needs gears badly. Under the old owner with the A4 and a 3200 Vig converter, the car went 12.69@105 with a fried 2-3 clutch pack just bouncing off the limiter and falling on it's face after the shift. That was on a 1.74 short time too. It's got potential, and I think a set of 4.10's will be a wake up call, but I still feel that the car is missing something somewhere.
A full breakdown on the car can be found in my sig. In decent weather about 3 months ago I went 12.988@107.98 with a 2.04 short time, crossing the traps in third at 6200 RPM.
