Dyno results...
Old Sep 24, 2003 | 11:35 AM
Camaro_Maniac63's Avatar
Dyno results...
Got the car dynoed a couple days ago. This was on a dynojet, and the numbers are SAE corrected.
294.4rwhp @ 5750rpm
308.0rwtq @ 3500rpm
The major mods are Moroso CAI, SLP shorties, Hotcam w/1.6rr, home-ported heads, flowmaster muffler.
The first pull, with the guy shutting off at 5600rpm produced 278rwhp, and the power curve is still going up at 5750rpm... I think I will need to push my rev limiter to up around 6400rpm.
The torque curve is very flat The car makes over 300rwtq from 2500rpm to around 5000rpm.
Also, two guys in our club gained 13rwhp and 13rwtq just by opening their cutouts.
I am taking her to the track tomorrow, wish me luck.
Old Sep 24, 2003 | 11:39 AM
BlakeW5's Avatar
Nice. I althoughs thought that the hot cam would get you over 320 rwhp though, someone correct me if I'm wrong.
Old Sep 24, 2003 | 11:50 AM
Fastbird93's Avatar
Yeah, even with home ported heads you should have about 330+ at the wheels. Did you get the heads flowed? I've heard it's very easy to screw up your head numbers if your not careful when home porting LT1 heads. Have you had a tune done also?
I think I will be there if I can rev the engine up a little higher... Plus I don't have a cat-back on the car, just a muffler.
I haven't had it tuned either but AFR was not too bad, around 12-13 the whole time except for 5500rpm, when it dropped to low 11s.
Old Sep 24, 2003 | 11:52 AM
MentalCaseOne's Avatar
Dang!! 320 rwhp? that would put me like at 400 cranck shaft horses!!! Now thats one mod for a street machine like mine... will the Tranny and rear end hold up??
Marvin
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
