Dynatech LT's VS Hooker Headers Super Comp LTs.
Old Sep 15, 2003 | 08:03 PM
  #16
dreamer1q's Avatar
I cant believe I am doing this, but I agree with Trey...to a point. You do need to have them welded up, they leak terribly if you dont. The ground clearance is awesome, I have never hit them, even when I got air in my car crossing a intersection. Side note, that was awesome They do have one problem though, at least with my application. I had to grind the steering shaft a little to get them to clear, but I went with the largest primarys I could get. They also dont play nice with the PIECE OF CRAP, LEAKING, JUNK, DONT EVER BUY ONE CANTON OIL PANS I had to beat one of the primarys to get it to stop rubbing. They also are a tight fit for the low oil sensor with a stock pan. You have to eliminate the low oil sensor with THE PIECE OF CRAP, LEAKING, JUNK, DONT EVER BUY ONE CANTON PAN. One thing I have noticed is the Hookers seem to have better plug change clearance. I have looked at alot of my friends motors that have Hookers, and you definelty have more room with Hookers.
Q
Old Sep 15, 2003 | 08:07 PM
  #17
TreySpeed's Avatar
On permanent vacation
Q
you ever get my PM?
btw- come to think of it, mine rubbed on the steering columb slightly as well, very little though
Old Sep 15, 2003 | 08:08 PM
  #18
TreySpeed's Avatar
Q
you ever get my PM?
I was expecting SOME kind of responce
btw- come to think of it, mine rubbed on the steering column slightly as well, very little though
Old Sep 15, 2003 | 11:37 PM
  #19
Bersaglieri's Avatar
Treyspeed,
when you refer to dynatech being superior in every way, are you speaking of the stepped or race versions of Dynatech? also in what ways are they superior? HP? Torque? I am thinking of going true duals, and these two headers are my choices, any recommendations or insight? Thanks
Bersaglieri
Old Sep 15, 2003 | 11:46 PM
  #20
TreySpeed's Avatar
Originally posted by Bersaglieri
Treyspeed,
Bersaglieri
they slip in without jacking the motor or anything weird.
they dont limit ground clearance
plug access is fine
Old Sep 16, 2003 | 12:39 AM
  #21
Thanks for the input, i;d rather have an easy, profanity free install
Bersaglieri
Old Sep 16, 2003 | 12:44 AM
  #22
5.0THIS's Avatar
Q
So what's your opinion on Canton oil pans? Should I buy one?
Old Sep 16, 2003 | 09:28 AM
  #23
TreySpeed's Avatar
maybe 2
(no seriously, you ae going to need 2 because odds are one will fail)
Old Sep 16, 2003 | 11:02 AM
  #24
Antz97ZNJ's Avatar
All long tubes generally perform the same, no need for back n forth discussion, whatever is the better price go w/.
Old Sep 16, 2003 | 11:23 AM
  #25
Z-RATED94's Avatar
This IS scary. I to agree with Trey, but only because I was told by Bret that he likes the Dynatechs.
Old Sep 16, 2003 | 11:34 AM
  #26
ibanez6rg's Avatar
I like my Jet-Hots
Old Sep 16, 2003 | 12:09 PM
  #27
TreySpeed's Avatar
dyna techs are much more expensive than jet hots- about $200 more
Old Sep 16, 2003 | 12:27 PM
  #28
ZPaul2Fresh8's Avatar
One thing to add, I have Dynatech headers and I love them, but if you have the factory oil cooler, you'll have to ditch it or buy an oil filter re-location kit like I had to!
Never had a problem with the steering linkage though, nor did I jack up the engine. The only PIA was the dipstick tube (Which you have to remove for all long tube headers)...
Come to think of it... maybe I should WELD my collectors on? I thought I smelled exhaust under the hood
Thanks guys
Oh yeah, enjoy driving with open headers while you can!
Old Sep 16, 2003 | 01:02 PM
  #29
Sweetred95ta's Avatar
The Dynatechs that I have seen are only $429, ceramic coated. How are the jet hots ($550) about $200 more. Am I missing something??
Benji
Old Sep 16, 2003 | 01:14 PM
  #30
WOOS1's Avatar
Benji
That price of the Dynatechs does not include the collectors. Expect to spend at least another $200, depending on the style of collector chosen.
