dynatech lt's and true dual Q's
Old May 3, 2004 | 03:20 PM
greatwhitez's Avatar
I am currently underway installing my dynatech race long tube headers. they have the 3" collectors. I'm wondering what other guys are using as far as an x-pipe or h-pipe to run off of the collectors to a set of dynomax bullets then turn downs. Does anyone know a specific x-pipe that will work with these headers. or will it have to be a custom job. I know that the dynatechs are the same header as the FLP design sells.
Thanks,
Nick
Old May 3, 2004 | 05:08 PM
drewstealth's Avatar
I'm not too sure how much difference the dynatechs are compared to the hooker lt's but there was a thread a few days ago about a summit xpipe that was a perfect fit for the Jet hot Lt's. The guy did the whole setup for about 200 i think. It looked really good also.
Old May 3, 2004 | 11:01 PM
yes, i know that thread you talk about, it looked awesome, exactly what i was hoping to do. i am just unsure as far as the differnces between the dynatech's and jethots, and to what i need to do to "fab" up a true dual set up. Any help would be wonderful. THanks Guys.
Nick
Old May 3, 2004 | 11:18 PM
flyinZ's Avatar
I have the Dynatech LT's....with an x-pipe...
Old May 3, 2004 | 11:20 PM
really thats good to hear. Did you custom make it or what xpipe did you use. it would be extremely helpful if you could gimme a hand trying to fab this thing up as far as dimensions. or just part numbers of what to use.
Thanks,
Nick
Old May 3, 2004 | 11:26 PM
philcam01's Avatar
dynatech's here, I had my x-pipe made though and I'm running it all threw 3inch also but with spin tech's this thing sounds mean as hell. I love the headers the only down fall is the #5 plug come time to change it. Good luck with the install
Old May 3, 2004 | 11:29 PM
did you guys just get rid of the air and egr? im still wondering on what i should do, its going to be on a 396 lt1 w/ the gm 847 camshaft so emissions is a wash cuz no way in hell can it pass.
how much does the x pipe cost to fab up? I'm planning on xpipe to bullets to turndowns.
flyinZ's Avatar
I used a summit 3" x-pipe, 3" muffs,and dumped it before the axle, using turndowns...
Old May 3, 2004 | 11:31 PM
thanks flyinz and phil this is tons of help for me. As far as the summit xpipe does it bolt right up to the 3" collector?
Old May 3, 2004 | 11:32 PM
philcam01's Avatar
yeah no air or egr. also the hole exhaust ran me $450 but that was mufflers and all, but I have it under the axel all the way to the back. It was just way to load to ride around with just turn downs on.
Old May 3, 2004 | 11:48 PM
yea thats awesome. the dynatechs seem to be amazing, i love how they look. as far as not using the egr how did you plug it? and how was the install on the headers?
Old May 3, 2004 | 11:55 PM
philcam01's Avatar
they were not that bad, just pull the steering shaft , the back plugs on both sides, and the starter. They both go though the bottom with no problem at all. As far as the EGR goes I just made a block off plate, the vac line that runs to the egr will need to be block off with something.
Old May 4, 2004 | 12:42 AM
med_reject's Avatar
Will this setup work with hooker longtubes?
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
