Dura-bond cam bearings...need advice
Old Dec 22, 2006 | 08:39 PM
wrd1972's Avatar
Check out this link for the three types of Dura-bond am bearings for LTx.
http://store.summitracing.com/egnsea...115+4294889104
My engine has the standard and performance and wants to know what I want to use. I cant find a clear cut answer to if the performance bearing is just better performing or longer lasting.
I am building a new 355 LE2 with about 400RWHP and I want a cam bearing that will last. Longevity is higher priority than power when it comes to the cam bearings.
What about these coated ones, they sure cost a lot more.
Anyone want to chime in?
Old Dec 22, 2006 | 09:27 PM
crushah's Avatar
I'd spend the few extra bucks for the better bearings. The bearings just went out on my .383 set-up causing damage to the crank and the block.
Old Dec 22, 2006 | 09:46 PM
MachinistOne's Avatar
Use the performance bearings, you don't need the coated.
chuyz28
Apr 9, 2015 09:36 PM
jj_burchiel
Mar 5, 2015 07:05 AM
Killer94z
Jan 13, 2015 12:06 PM
1775.Z28
Jan 11, 2015 10:51 AM
chuyz28
Nov 25, 2014 11:14 PM
