dumb question time
Old Feb 18, 2004 | 09:48 PM
1msfyter's Avatar
dumb question time
can i remove just the oil filter? How much oil will come out?
I need to put on an oil cooler setup and the oil is only 2 weeks since i changed it.
Old Feb 18, 2004 | 09:54 PM
jdizzell's Avatar
Why do you need to change the oil filter with the cooler?
Old Feb 18, 2004 | 09:56 PM
EviLZ28's Avatar
You can take the filter off and not drain the oil. You will just loose the oil thats in the filter and a liitle might run out but you will not loose alot. Its ok to do it. Just make sure you check the level before starting it after you put it together and add the required amount back.
Old Feb 18, 2004 | 09:57 PM
1msfyter's Avatar
cool cool cool. Thanks
Feffman
Oct 9, 2015 05:42 AM
capebuf
Jan 13, 2015 07:22 PM
ModdedNerd
Dec 25, 2014 05:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
