duals and LTs without crossover pipe?
Old Dec 20, 2004 | 08:01 PM
95M6Z's Avatar
I see that most people with a dual exaust set up on 4th gens have a crossover pipe in the form of an x or h pipe. And i was wondering in the next few months when i get a set of LTs if i need a cross over pipe or if I can run 2.5 duals and just dump out before back tire. Is there any gain or loss with this. I also wanna do it to cheat emissions cuz then i can run 2 cats and they only read out of one pipe so its gonna get only a 4cylinder emissions reading from the sniffer. Any input wuld be killer. Adam
Old Dec 20, 2004 | 09:06 PM
jdizzell's Avatar
Re: duals and LTs without crossover pipe?
H pipe would be best, but the reason for a center section is to have the exhaust flow at the same rate. If you run duals you will have to re-route your fuel lines on the driver side. I have not seen a dual 4th gen without the fuel lines re-routed.
Old Dec 20, 2004 | 10:44 PM
95M6Z's Avatar
thanks for the input and ic what you mean with the fuel lines and such. i still wanna do dual but maybe i'll do it gto style on the one side, i just want an exhaust that not everyone has. thanks
Old Dec 21, 2004 | 01:38 AM
dmoor88's Avatar
youll see more gains, typically, with an X pipe over an H pipe. The H pipe gives a deeper sound however. That's what ill be going with when i have my duals fabbed up next week. Id rather have a deeper sound over the small HP gain id see by going with an X pipe.
Old Dec 21, 2004 | 10:11 AM
Loadre's Avatar
I have duals with an x-pipe and stock fuel line location.
Old Dec 21, 2004 | 12:09 PM
superal's Avatar
I didn't reroute my fuel lines either. I've been running my setup for 6 months or so and all is fine. I personally like the sound of an x-pipe. There's a video out there of an x-pipe and you might like that sound over the big truck sound that most cars on the road have.
Old Dec 21, 2004 | 09:15 PM
revtime's Avatar
I also run true duals without a crossover and stock fuel line location.
I did wrap the lines with thermal tape just as a precaution.
I run purple horny header mufflers straight off the Hooker LTs.
Slayer
Aug 17, 2015 03:55 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Devinfoote87
Jul 30, 2015 09:54 AM
Jlo
Jul 29, 2015 03:52 PM
Catmaigne
Jul 14, 2015 05:17 PM
