dual valve spring install need help
Old Jan 2, 2014 | 11:52 AM
  #31
Chimera96's Avatar
Re: dual valve spring install need help
Originally Posted by SuperSportSS
Any clue on the batch number? I still couldve gotten a set from back then. Cause i know these things sit sometimes
Originally Posted by lt1-xjs
They had a blue stripe on them, the new redesigned spring is all silver.
it was a specific batch #. a quick internet search says this from 2007
1) 49253
2) 049045
3) 49826
4) 050808
5) 051791
IIRC correctly it was initially the 1st batch # listed above but the "internet" says the others also. The box the springs come in have the batch # on them. Call Comp Cams and ask about your specific batch# if you have concerns.
It was not isolated to the "blue stripe", all Comp 918's had a blue stripe. Mine do and have been fine for 10 years
thread source for 411
replacement 918s ??? - PerformanceTrucks.net Forums
Old Jan 2, 2014 | 07:21 PM
  #32
Bersaglieri's Avatar
There have been plenty of beehive failures, not just special batches or Comp brand. I try to warn as many people as I can, enjoy.
However they do work decently in flat tappet applications under 4000rpm.
Old Jan 3, 2014 | 02:20 AM
  #33
SuperSportSS's Avatar
I plan to take my car to 7k but not daily. Just when its play time. I just need to get this thing out of the garage for now, if i dont feel right about these beehives ill just buy a better brand. Anyone have a link to the 918s? I might have gotten a completely different style or number of beehives.
Ill prob just google beehive 918 instead of having you guys do all of the searching for me. Typical lazy me
Old Jan 3, 2014 | 02:26 AM
  #34
Looks like these are the springs i have, the comp 26125-16 says theyre for the 4.6l mustang motor. But from what ive seen theyll work for the lt1 with the stock retainers also. So if my motor drops a valve looks like my speed shop pays the repair bill
Old Jan 3, 2014 | 09:27 AM
  #35
Chimera96's Avatar
26125 is not the right spring for the LT1 at all. your stock "retainers" will not fit these, or any other "bee hive" spring. "locks" for the 918's are 7 degree so you can use your stock 7 degree locks unless you chose 10 degree retainers...then you need 10 degree locks.
Old Jan 3, 2014 | 04:16 PM
  #36
Jesus, what a train wreck... I almost want to believe this is a joke, almost.
Just call Lloyd Elliott and buy the springs he tells you to. No more messing around. Here is his website: http://elliottsportworks.com/ He knows LT1 valvetrains inside and out, call him and take his advice.
Old Jan 4, 2014 | 04:55 PM
  #37
Already went and took those springs back they called and had me mixed up with another customer. So i took my spare set of heads up there and we got the correct springs and locked them in to my spare heads. Finally got the right ones.after alot of wasted time
Old Jan 4, 2014 | 05:33 PM
  #38
Well I tried, good luck with that.
Old Jan 5, 2014 | 05:05 PM
  #39
Well springs are installed and car was started for the first time. Runs GREAT started first hit of the key. Springs seem to be holding up great
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
