dual cats on a hooker Ypipe for LT1 longtubes..can it be done?
Ok..i just need it for about 30 min of total run time(so the inspector can see that there are new cats on the Ypipe then they will be coming out.where can i get the CHEAPEST POSSIBLE cats that are small enough to put spliced into the hooker Ypipe for the LT1 hooker long tubes.and can this even be done? liks i said i dont care about performance or anything i just need new cats on the Ypipe. let me know this is really gonna help.
Re: dual cats on a hooker Ypipe for LT1 longtubes..can it be done?
Can be done and has been done. I had one for a while
http://www.bfranker.badz28.com/94z/xpipe.jpg
http://www.bfranker.badz28.com/94z/xpipe2.jpg
Not cheap though.
Not cheap though.
Guest
Posts: n/a
I am planning on using these. They are small enough that they should give very good clearance and they are some of the best priced that I have seen!
http://216.178.81.107/iwwida.pvx?;it...0%201?comp=ppe
yeah brent..if i had the extra money thats the way to go..but N2o thats an awsome idea..ill be buying those in about 2 months to put on my car..thanks
another question..im lookin at the hooker Y-pipe and it doesnt look like ill be able to splice anything into it...anyone know if you can even fit cats in there?-mark
Guest
Posts: n/a
I have got a Mufflex right now and I am planning on changing to a Hooker for more ground clearance. I think that with the Hooker, it will be perfect for installing a couple of cats. It has stright lines on both sides that will work really well. It will just be a matter of measuring and cutting the pipe and the bolting or welding the cats on.
Jan 5, 2015 07:14 PM
