DTC 71....Trying to get A/C working after engine swap.
Old May 18, 2007 | 01:23 PM
xxsaint69x's Avatar
Tried charging the system today (its all empty) but the compressor wont kick in at all so i cant get any freon in the system. I get a DTC 71 on my scanmaster which is for something with low temperatore indicated? I dont know, i checked the voltage at the pressure sensor and its fine. Everything worked fine before removing the engine......any ideas where to start looking?
Old May 18, 2007 | 03:26 PM
seawolf06's Avatar
71 - A/C evaporator temp sensor circuit
Old May 19, 2007 | 09:03 AM
JP95ZM6's Avatar
Adding some refrigerant is always enough to get my a/c to come on when I am charging. First you need to evacuate the air from the system with w/ vacuum pump. With an evacuated system you should be able to get some refrigerant to feed in even without the compressor on. Did you do that?
Then you can start adding refrigerant through the LOW side port. It should feed pretty good on an evacuated system. Can upside down will feed fastest. Warming the can a little under hot water first helps too.
Old May 19, 2007 | 09:41 AM
chevyinside's Avatar
if you swaped a v6 to a v8 your gonna need the evap core temp sensor that is mounted in the car
Old May 19, 2007 | 11:40 AM
xxsaint69x's Avatar
ya, i need to evacuate the system, i can only get 1/4 of a can in there
Old May 19, 2007 | 03:21 PM
cloim's Avatar
The compressor will NOT kick on if there are ANY ac related codes. PCM will not let you continue.
Fix the evaporator temp sensor. It's under the dash, passenger side. Attached to the side of the plastic case housing the HVAC components. Three wires lead to the connector, two wires from the connector lead to the temp probe attached to the evaporator core.
Old May 20, 2007 | 06:27 PM
JP95ZM6's Avatar
Oh, he switched from V6 to V8. I did not know that. I think the V6's have an orifice tube a/c system, as opposed to the V8's TXV system, right? Does the orifice tube system even have an evap temp sensor?
Old May 21, 2007 | 02:01 AM
blown383's Avatar
ttt for future reference
-B
Old Jun 7, 2007 | 07:48 PM
xxsaint69x's Avatar
for future reference..i forgot to connect my evaportator sensor inside the car when i had the harness out of the car...gosh i feel like a dumbass lol
oldschool
Feb 9, 2016 09:21 PM
nballisru
Dec 14, 2014 05:01 PM
CaRParts102
Dec 6, 2014 08:45 AM
pologreen97z
Dec 2, 2014 10:42 AM
siguy
Nov 27, 2014 10:07 AM
