DTC 61 AC issue
Old Aug 2, 2008 | 03:53 PM
wrd1972's Avatar
DTC 61 AC issue
Car is posting DTC 61.
Right now the AC compressor on the motor will not kick in. If I short across the relay, the compressor will kick in so the problem is not circuit related at least from the relay to the compressor.
If I pull the PCM fuser and reset, the AC does work and make cold air for a short time then the code again comes back and then the AC compressor wont work.
Any thoughts. Its hot as hell here.
Old Aug 2, 2008 | 04:32 PM
Your charge is probably low. The PCM is protecting the compressor from damage by shutting it off.
Old Aug 2, 2008 | 04:33 PM
camarozz95's Avatar
I had the exact same problem with mine last week same code. Mine actually turned out it just needed a recharge it took about 1 can of R134a. At first I was stumped cause mine low side reading said it was full, but my high side was very high and flucuated a lot. So I started filling and it took a whole can and still read it could take more but I stopped cause the air was blowing hella cold.
here's my thread: https://www.camaroz28.com/forums/sho...d.php?t=623558
Old Aug 2, 2008 | 04:43 PM
wrd1972's Avatar
Thanks guys. I have a can of 134A. Do I need guages to monitor the pressure? What do they typically cost?
Old Aug 2, 2008 | 04:55 PM
camarozz95's Avatar
yeah just get a can that has a guage built on it mine was like 20 bucks at advance auto parts.
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
timmy39120
May 8, 2015 11:41 AM
sseeya
Apr 9, 2015 06:38 AM
David Dorris
Jan 17, 2015 08:10 PM
dreamer1q
Aug 20, 2002 11:19 AM
