DTC 36, Did a search here and found ...
Old Jul 20, 2005 | 11:30 PM
Lt1t56's Avatar
Today the service engine light illuminated on my car, checked for codes, found DTC 36. After searching here for a while found the first thing to do is clear the code and see if it comes back and how often.
It seems that it could be a code that may only appear at times and if it keeps reoccuring then there is a problem, and the best place to start is electrical connections and grounds before pointing the blame at a defective opti. Sound right ? Anything else I should know ?
Thankyou.
Old Jul 20, 2005 | 11:33 PM
BLinindoll's Avatar
Re: DTC 36, Did a search here and found ...
you can hope, but its prolly your opti.
Old Jul 21, 2005 | 01:12 AM
'94 Red Dragon's Avatar
My car through that code today, i read on datamaster and it said High res.
What causes this code.
Old Jul 21, 2005 | 09:10 AM
kevm14's Avatar
When the PCM detects a discrepancy between the low res and high res signal. In other words, it's an electronics problem, not a cap & rotor problem. Usually it means the opti needs to be replaced. It CAN be a harness issue, apparently.
Old Jul 21, 2005 | 06:01 PM
So i need to change my opti
cmsmith
Apr 11, 2015 09:37 PM
squarehead
Jan 15, 2015 07:02 PM
Redbird
Sep 14, 2002 09:18 AM
Redbird
Sep 3, 2002 02:08 PM
Redbird
Jul 20, 2002 06:08 AM
