Dtc 26
Old Nov 2, 2004 | 09:05 PM
LT1Squirrel's Avatar
Dtc 26
checked my codes for the 93 today and got DTC 26, Quad-Driver Module (QDM) #1 circuit, the hard question would be how will i be able to correct this?....the simple question what be, what the hell is it?
edit: tried a search came up with nothing....93 codes are different from later years....and my Chilton says absolutely nothing on it
Old Nov 2, 2004 | 09:34 PM
Gimpster's Avatar
Re: Dtc 26
Ironically, I had this on my 93 as well.
http://home.comcast.net/~fastbird/Tr...ech%20Aids.htm
Basically, from what I can see code 26 is QDM #1 ... QDM = Multiplexor in the PCM that allows it to control more than one device on one address line.
So in english, for whatever reason your ECU thinks its having trouble controlling either: 1.) The Air pump, 2.) EGR solenoid or 3.) evap purge canister.
I finally got tired of seeing this code in Data Master and disabled DTC #26 in tunercat
Old Nov 2, 2004 | 09:51 PM
Re: Dtc 26
Look at your AIR pump fuse, first.
Old Nov 3, 2004 | 11:01 PM
Re: Dtc 26
Air pump is the thing below the stock airbox correct?
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
