Dropped keeper
Old Aug 3, 2005 | 10:37 PM
weinerschizel's Avatar
Dropped keeper
I couldn't sleep. I'm sure nobody else knows how to find one of these devils but figured laying there sleepless over it.... that asking around couldn't hurt.
I was swapping out my valve seals w/ the engine in the engine bay. It was going very smoothly... until on exhaust valve cylinder 2 the keepers were stuck. So I gave it a good grunt and they came loose and went flying. They are 15 degree keepers for my comp cams dual valve springs. I found one of them immediately. It had fallen under the car. Then I searched EVERYWHERE for the other for about an hour. Anybody know of any crevicies that are good to look in?????? I so hope it didn't go down into my lifter valley. From what I could see it wasn't down there... I use guide plates so I figured there wasn't much of a chance for it to slip in there. However, I figure I'll have to pull the intake if I don't find it sooner or later .
Old Aug 3, 2005 | 10:40 PM
Re: Dropped keeper
Impossible to say where it went. I don't even touch the keepers without a magnet right there next to them.
Old Aug 3, 2005 | 10:41 PM
turbo_Z's Avatar
Re: Dropped keeper
If you look *EVERYWHERE* you will find it... eventually!
Old Aug 3, 2005 | 10:46 PM
easyc4's Avatar
Re: Dropped keeper
it will be in the last place you look...:P
Old Aug 3, 2005 | 10:53 PM
Re: Dropped keeper
Gosh I'm pulling my hair out Was using a magnet however, I set it down for this one cause it needed that little extra grunt, both hands. (I'm using a breaker arm style compressor). Well I probubly should pull the intake anyways. I had found chuncks of valve seal ontop of my heads... sigh... i should have just pulled the motor. oh well. thanks for the help!
Old Aug 4, 2005 | 02:28 AM
carolinacasper's Avatar
Re: Dropped keeper
I have a theory that when you drop something between the engine and the wheel well that it actually dissapears. I dropped a keeper down there along with a ring my GF gave me...didnt fall out on the ground!!???!!! Looked for hours and didnt find either???
Old Aug 4, 2005 | 02:51 AM
sssalah's Avatar
Re: Dropped keeper
Didn't know they made 15* keepers!!! If that lock hasn't went in the engine then it's probably resting on the k-member.
Old Aug 4, 2005 | 07:07 AM
Re: Dropped keeper
That was my thought too. There isn't much else down there for it to rest on. So I search most of the time on that. I'm going to lift the engine up here to double check my bolts on the oil pan (seems to be leaking a tad) and then I'm going to take a closer look at that.
Talk about puting a hinderence on my work! Hopefully I can find it and get back in gear.
Thanks a bunch. I was able to sleep after posting last night
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
kandied91z
Sep 30, 2015 11:43 PM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
