Driving and lost all oil pressure!
Old Jan 2, 2012 | 06:55 PM
  #16
raroz28's Avatar
Re: Driving and lost all oil pressure!
Originally Posted by faster01nu
Well have the oil drained and saw little gold looking flakes. so im sure some bearings will need replaced. Will i be able to do this without pulling the motor? Ill oost pics tomorrow.
No, it will have to come out because the crank probably has some damage. I could not imagine doing this job on my back. Don't even waste the time.
If it happens to have damage, I would not recommend paying a shop to grind it. It's too expensive for how cheap you can get a crank. I had several cranks offered locally at $50 each. Got an affordable $35 polish job and I was good to go.
These cranks are interchangeable so you don't need to worry about balancing, it will work just fine without any work.
Old Jan 2, 2012 | 08:26 PM
  #17
faster01nu's Avatar
Originally Posted by nick3
i say ur crank will need work or be replaced also. need to go thru bottom end. no since in fixing one part and another on its way out. pull motor. how many miles are on ur motor?
The motor has 87000 on it.
Old Jan 3, 2012 | 12:42 PM
  #18
faster01nu's Avatar
This is the part I said was loose and the oil was coming from the top where the silver piece meets the block..
Old Jan 3, 2012 | 12:44 PM
  #19
faster01nu's Avatar
2nd look...The oil would squirt out between the two pieces. When I took it off this time, it did not seem to have any pressure build up.
Old Jan 3, 2012 | 07:54 PM
  #20
my1994z28's Avatar
Your pics did not show up..
Old Jan 7, 2012 | 06:34 PM
  #21
faster01nu's Avatar
Ok. thanks. I guess I dont know the right way to put pic in? lol Is there directions somewhere??
Old Jan 7, 2012 | 09:07 PM
  #22
The link you inserted appears to be for your google mail account. Were you looking at the picture, and did you copy and paste the address into your post, using the [img] tags? If they are in an account that requires a password, the link won't work for anyone but you.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
