Driveshafts
Old Aug 5, 2003 | 11:22 PM
BlakeW5's Avatar
Driveshafts
What are your opinions on the 1LE and LS1 driveshafts? Both are aluminum, correct? Are there any recurring problems inherent with either? Also, how much weight would they save me over a stock driveshaft?
Old Aug 5, 2003 | 11:28 PM
Z28ROC's Avatar
The LS1 is a very smooth unit, compared to the LT1 shaft. You can get one from a wrecking yard for around $100. I didn't weigh it but it felt about 15-20lbs lighter also.
Old Aug 5, 2003 | 11:39 PM
EviLZ28's Avatar
1Le is lighter Ls1 is bigger in diameter for strength. So do you want lighter or stronger?
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
