Driver's window problem
Old Jul 25, 2003 | 11:41 AM
97silverz28's Avatar
I've got an intermittent drivers door window. The Pass window works fine. The window will go up & down then somethimes get stuck. Eventually, it'll work & get back up, for now.
My question is, is there a replacable switch, or does the switch just operate a contact block & I should look for the relay?
Thanx for any help.
Old Jul 25, 2003 | 12:16 PM
bt95formula's Avatar
Mine did the same thing before the motor stopped working. It was bad and I had to have it replaced. I doubt it is the switch but could be
Old Jul 25, 2003 | 12:19 PM
It's the original motor. I was afraid of that. I was hoping it was a quick fix.
Looks like I'll have to get it fixed, I might be buying a '02 SS & the window will have to work if I sell the car.
Thanx again.
Old Jul 25, 2003 | 12:20 PM
buelldevil's Avatar
Sounds like a motor, but if you want to try a switch,you can pick one up at the dealer for about $10.
Old Jul 25, 2003 | 04:47 PM
Thanx guys. I wasa just troubleshooting it. Looks like its the motor. It gets hot, then quits, cools down then works agin. Jumped out the switch, its not that.
Old Jul 26, 2003 | 07:56 AM
revtime's Avatar
If your gonna replace it yourself I suggest you do it the Shoebox way, I changed the motor out in about an hour just piddling along and it was way easier than pulling the regulator out.
Old Jul 26, 2003 | 11:40 AM
steeltag's Avatar
How do you replace the window motor, the Shoebox method? I've gone to the website and don't see anything on window motor replacement. Also, I went to a1electric's website and saw a photobook of them installing a pw on a s-10 pickup. It looks difficult...plus, you need a rivet gun. Did you have to do something similar when you said it only took you an hour to change it over? I'm trying to fix a girlfriend's driver's pw on her '96 Z28. Thanks
help!
steeltag
steeltag@hotmail.com
Old Jul 26, 2003 | 05:45 PM
Canadian z28's Avatar
That would be the window motor i had the same problem, Then i fixed the motor and the problem was solved. I just did it 3 weeks ago, not that hard of a job.
Old Jul 26, 2003 | 05:54 PM
help!
steeltag
Don't see anything? It's at the top of the "How to" section. . Click Tech Page in sig.
Old Jul 28, 2003 | 02:40 AM
steeltag's Avatar
Thanks Shoebox , I must have been at a different site. I clicked on the hyperlink you have in your sig and was directly to where i needed to go.
Kelly
dale3in98
Feb 14, 2015 12:18 PM
warmeck
Feb 2, 2015 12:44 AM
Fatdog2
Jan 24, 2015 12:08 AM
Collector Car
Jan 5, 2015 10:58 AM
Snoman73
Nov 17, 2014 07:22 PM
