Drivers Side Wiper Blade!
Old Aug 11, 2003 | 08:07 AM
EaC95Z28's Avatar
my old drivers side blade was starting to not wipe a little square toward the bottom of the windshield probably about 6 inch by 6 inch square. So i figured that i needed new blades. ok so i went and bout some new replacement blades, and put them on. worked fine, wiped the whole windshield and were fine. i just washed my car yesterday and i always lift my blades up to clean windshield/blades. i put them down, this morning there was condensation on my window around 7:45. i was heading to work. use my wipers once to wipe it off and i miss the exact same spot on my drivers side. it is sooo annoying.. it worked fine then 3 days later it doesnt. how do i fix this. i think i am going to bend it down. this is the side in the middle of the windshield next tot the little triangle the two blades make when they wipe thanks!
Old Aug 11, 2003 | 08:24 AM
Bobbys_97_Z28's Avatar
I HAD THE SAME THING HAPPEN
it wasnt much, but the little bit it was pissing me off, well anyways...when you put down your arm, theres a srping in the arm and it holds it down, push down on that so that its firm against the window and that should help out
Old Aug 11, 2003 | 08:39 AM
RacinZ's Avatar
Cool I will try that also, mine did the same thing this morning.
They must communicate to each other somehow. (hey lets mess up everybodies windshield) Maybe one day they'll take over the world
Old Aug 11, 2003 | 10:03 AM
EaC95Z28's Avatar
I think i might have fixed it but it still wipes differently and it squeasks now
Old Aug 11, 2003 | 10:26 AM
Hyperspeed97z28's Avatar
you need to get GM replacements....
its one of these two.....
Part # 12481132
Part # 22121694
and Yes it is the more expensive one but the cheaper one should work....
Part # 12481132
Part # 22121694
ChrisFrez
Feb 22, 2015 08:47 AM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
