Drivers side head exact same casting as passenger correct?
Old Mar 1, 2005 | 07:01 PM
Pasky's Avatar
Asside from the temperature sensor and coolant lines and blocked thread holes the castings are the same correct?
Old Mar 1, 2005 | 07:23 PM
Re: Drivers side head exact same casting as passenger correct?
The heads are identical mirror images of each other and can be used on either side. It would be one head part number and they just used two of them-one on each side.
Old Mar 1, 2005 | 07:25 PM
Pasky's Avatar
Awesome, thought so, thank you shoebox.
Old Mar 1, 2005 | 11:49 PM
1racerdude's Avatar
Get the plugs for temp and crossover out and swapped before swaping sides or you can't hook up the line behind the heads or temp sender on drivers side. You will have one hell of a water leak on the front too.
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
Bando
Oct 7, 2002 07:36 PM
