drive train problem
Old Sep 11, 2003 | 02:51 PM
sean1997ws6's Avatar
drive train problem
When my T/A gets up to about 95 and above i get a vibration and nosie that starts to come from the rear protion of the car. like transmission back. I was thinking it could be one of the little weights on the drive shaft. but i dont know, anyone ever had this problem?
Old Sep 11, 2003 | 04:18 PM
GREGG 97Z's Avatar
If you still have the stock steel driveshaft it's very likely the problem. You could try having the ds balanced but odds are it may still vibrate. The only real fix is to upgrade to an aluminum LS1 ds or a better balanced aftermarket shaft.
Old Sep 11, 2003 | 09:39 PM
where can i go to get the balance or where could i get an ls1 driveshaft for a decent price? Thanks
Old Sep 11, 2003 | 10:50 PM
dynomight's Avatar
I had very similar issues. LCA relocators solved the problem. This was after many shots in the dark, including new rims, TA, stabilizers, tranny mounts, gears, and tranny. Good luck with yours...
john
AdsoYo
May 2, 2018 03:21 AM
mark0006
Feb 3, 2015 05:12 PM
Jazsun
Dec 29, 2014 12:14 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
