Dreaded white smoke
Old Dec 26, 2003 | 02:40 PM
Javier 94 Z28's Avatar
Dreaded white smoke
Hey everyone. After my lunch break today, I jumped into my car and turned the key. It made a thunk sound and thats it. I turned it again and the same. I turned it a third time and she started up. I start backing up when I notice a ton of white smoke. Is this a blown head gasket? I just had the Opti replaced about a month ago so I'm getting really tired of expensive fixes. Are there any other possibilities and whats involved with fixing a head gasket? Thanks
Old Dec 26, 2003 | 03:14 PM
Red96Lt1's Avatar
Head gasket or a cracked head. Has the engine been over heated lately?
Old Dec 26, 2003 | 03:27 PM
No, in fact I didn't change back from the 160 stat this winter. It had a low coolant light for awhile after the opti replacement, but I added some and it went away. The engine hasnt been above the 180 mark on the gauge.
Old Dec 26, 2003 | 03:32 PM
anasazi's Avatar
check oil for milky crap
check coolant for oil floating on the surface
Old Dec 26, 2003 | 03:58 PM
I dont really see any milkiness to the oil, but it just happened so i dont know if it has had time to mix around. I also turned it off right away.
Old Dec 26, 2003 | 06:03 PM
94_Z28_guy's Avatar
Sounds like a head gasket.
It is not expensive to fix yourself. Min. about $100 bucks for gaskets. Having someone else to do it can be expensiive due to all the labor involved to get to the head gaskets.
If you do it yourself it is cheap but a little time consuming.
Old Dec 26, 2003 | 07:15 PM
InjectedSS's Avatar
how many miles is on the car? i see its a 94. im assuming the head gaskets are stock... more than likely they are the culprit.. No big deal.. real easy to fix.
Old Dec 26, 2003 | 07:17 PM
Kataklysm's Avatar
If you're gonna take the heads off may as well get them ported
Old Dec 26, 2003 | 09:16 PM
InjectedSS's Avatar
WERD
Old Dec 28, 2003 | 10:32 PM
The car has 99,820 miles on it. I actually decided to go out and buy a new car yesterday, so now I have a no stress chance to dig into the LT1 and fix that prob and hopefully mod it out over the course of the next couple of years (still in school). Don't be surprised if I jump on here to ask some more questions! Thanks all
IndyZman
Oct 22, 2015 02:17 PM
Hal Fisher
Sep 30, 2015 09:03 PM
frankrizz
Sep 23, 2015 04:21 PM
jackpawt883
Sep 10, 2015 08:53 PM
