Draining Coolant w/Only Block Drain Plug?
Old Jan 4, 2008 | 07:20 PM
truedualws6's Avatar
Do you have to remove both the block drain plug and the KS to drain the
coolant for a head swap, or can you drain the block with just the drain plug?
Old Jan 4, 2008 | 07:22 PM
dangalla's Avatar
you have to change the oil anyway, i would just drain the rad and it will not make too much of a mess when you pull the heads
Old Jan 4, 2008 | 07:33 PM
joeSS97's Avatar
Remove both of them,otherwise you only drain one side.You dont want ANY anti- freeze in the engine.
Old Jan 4, 2008 | 07:43 PM
dangalla's Avatar
why? you really should change the oil anyway
Old Jan 4, 2008 | 07:44 PM
joeSS97's Avatar
Why not dump some sand in it too?
Old Jan 4, 2008 | 07:48 PM
tireburnin's Avatar
I've always only drained one side and used a shop vac on the water pump for the other side. It pulls all the water out of the pump and block so it can't drain onto your opti when you pull the pump off. I keep the shop vac handy durin any big engine work. I don't like seeing dust, dirt or water anywhere it shouldn't be. (sticking the shop vac on the
Old Jan 4, 2008 | 08:09 PM
speed_demon24's Avatar
I only did one but if I could do it over again I would do both. None of the coolant spilled out the side I didn't drain, but it was a little too close for comfort on the side I didn't drain.
Old Jan 4, 2008 | 08:21 PM
SS RRR's Avatar
I've always just drained the radiator and jimmied the water pump a little loose, put a drip pan under the car and all has always been well. Both drain plugs should be pulled if you want all coolant drained.
Antifireeze won't get passed the rings in time to drain it out of the cylinders. It's really is no big deal. As already stated the oil should be changed anyway. And sand is just a weeeeeee bit more harsh than a little antifreeze.
Old Jan 4, 2008 | 08:54 PM
Thanks for all the replies. I'll just suck it up and remove the block drain plug
and the KS. I may as well pull the starter just to make more room. What's
a few more bolts at this point anyway.
Magenta_Hearts
Mar 29, 2017 08:54 PM
warmeck
Apr 16, 2015 05:53 PM
robcarnut
Mar 20, 2015 03:40 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
