Drain coolant to pull int. manifold?
Old Jan 18, 2006 | 11:02 PM
droptop z's Avatar
I got a oil leak on the back of my intake manifold, will I need to drain the coolant before I remove it from my engine?
Old Jan 18, 2006 | 11:30 PM
Re: Drain coolant to pull int. manifold?
Coolant only runs through the throttle body (not the manifold). If you have done the throttle body bypass, there is no need to drain coolant.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Sandersen511
Jan 13, 2015 03:49 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
