Downsides of springs that are overkill?
Old Nov 8, 2004 | 10:32 AM
ford's Avatar
Just curious if i could hurt anything running springs that are good for .600+ lift with my hotcam and 1.6's
Ive heard its not good to do it, but wanted to know if it would really hurt anything besides performance.
Old Nov 8, 2004 | 11:13 AM
BigBlue95Z's Avatar
Re: Downsides of springs that are overkill?
OTHER THAN PERFORMANCE????!!!!!! WHAT ELSE MATTERS????!!!!!!
It really shouldn't hurt performance much. It will take about 5rwhp, topps.
You should be fine.
Old Nov 8, 2004 | 11:26 AM
TobyZ28's Avatar
I'm going out on a limb here talking about something I don't know a lot about, but wouldn't overkill springs put down more pressure and thus cause a bit of extra wear and tear on the valvetrain? So one downside might be a bit more wear than if they were not way overkill.
Someone correct me if I'm wrong
Old Nov 8, 2004 | 01:23 PM
Spinner's Avatar
Not necessarily. When you do springs, put a decent spring in. Bigger isn't always better, but its almost never worse, in our applications anyway. As long as you dont go so big that you kill your lifters, the bigger you go, the improvement in valvetrain stability and dynamics should offset any power loss that theoretically may occur because your using stronger springs.
Old Nov 8, 2004 | 01:26 PM
ford's Avatar
Sounds good, ive just heard that you could put more unwanted stress elsewhere on the valvetrain, which i didnt want to do.
Thanks guys!
Old Nov 8, 2004 | 01:30 PM
SStrokerAce's Avatar
http://www.rehermorrison.com/techTalk/03.htm
" I have never installed stiffer valve springs on an engine and lost power; the improvement in valvetrain dynamics more than offsets whatever additional power is required to overcome the springs' resistance."
Bret
Old Nov 8, 2004 | 01:57 PM
ford's Avatar
Well then i guess the springs that come with it, ill keep
Thanks guys for the quick and informative answers
Old Nov 8, 2004 | 03:02 PM
Red96Lt1's Avatar
Originally Posted by SStrokerAce
That's a good website. I haven't gotten anything done in the last 90 minutes because I've been reading those articles. Thanks for posting that site, I think.
Old Nov 8, 2004 | 03:35 PM
n2ceptor's Avatar
http://www.cranecams.com/?show=productNews
Alittle more info... Scroll down to valve springs....
Old Nov 9, 2004 | 01:32 AM
No Problem, I know the feeling.
Old Nov 9, 2004 | 01:42 AM
bunker's Avatar
You shouldn't loose any power with stiffer springs, not only do you get a more stable valvetrain, aslong as you have a 1 valve spring working against you but the other working for you, you'll never loose power. There are 16 springs, when one is opening, the other is closing, one is pushing the the cam to open the other so they just cancel eachother out.
The only power loss would occur is from these:
1. Lost heat energy as you compress a spring some of the effort goes away to heat so you're converting a very small amount of mechanical energy to heat energy from compressing a spring, but nothing lost from effort required to compress as a result of stiffness.
2. the roller on the lifter is now pushing much harder on the cam which causes more friction; therefore, causing some power loss there aswell.
Now the other drawback is your cam/lifters shorten their life span.
With my cam I'm running about 395LB open pressure at my lift, with higher lift it would be more. Regardless, I think the hydra rev adds another 70 LB at my lift or so, so a total of 465lb on the roller of the lifter, but only 395 on the plunger, good thing for the hydra rev.
Regardless, you'll most often only benifit from stronger springs unless you go totally overkill.
Old Nov 9, 2004 | 04:38 AM
rskrause's Avatar
Moderator
I wrote a "primer" on valvesprings that you might find interesting. Go to www.kennedysdynotune.com and click on the "Tech Tips" button on the lower left menu bar. Follow the link to "Valve Spring Tech".
Rich
Old Nov 9, 2004 | 02:56 PM
dmoor88's Avatar
toss on some 1.7's and have no worries
Old Nov 9, 2004 | 03:04 PM
ford's Avatar
With my new 227/233?? Puts me over .600
Old Nov 9, 2004 | 03:15 PM
dmoor88's Avatar
oh you mentioned your hotcam, thats the only reason i mentioned it.
