Double-Roller and timing cover
Old Mar 16, 2004 | 01:46 PM
Spinner's Avatar
Is any clearancing needed for the EX double roller and a 95' timing cover? Cam goes in tomorrow, this is the last thing on my list to check. Water pump shaft hole I have freeze plugged. LMK, thanks
Old Mar 16, 2004 | 02:03 PM
ibanez6rg's Avatar
What we did with my Cloyes was put grease on the timing chain and put the cover on, turned the motor over to see if any of the grease rubbed on the cover. Where there was grease, we grinded down on the timing cover. Seems to have worked pretty well.
Old Mar 16, 2004 | 02:05 PM
93ZM6Tally's Avatar
Did the same, no issues after a bit of grinding. I probably grinded more than I needed to, but I wanted to be sure that I didn't have any clearance issues. Biggest area of concern is the ridge around the hole for the opti seal. Really isn't too difficult though.
Old Mar 16, 2004 | 02:19 PM
Spinner's Avatar
Any pics?
Old Mar 16, 2004 | 02:32 PM
GetaZforgetGT's Avatar
I had to take mine off a few times but it really isn't that big of a deal.
I greased up the chain and did some test fitting.
Only problem is that if your taking the cover off a bunch of times you need to make sure your not tearing the front seal on the oil pan.
I used a die grinder for the thick area and a "handy andy" to get it all even and worked out. Overall its super simple.
Old Mar 16, 2004 | 03:20 PM
Spinner's Avatar
Is it only the area around the big gear needing grinding? Also, is it the sides, or is it the flat face part that needs grinding?
Old Mar 16, 2004 | 03:38 PM
Just the flat face or very front of the timing set.
Old Mar 16, 2004 | 03:40 PM
Spinner's Avatar
That's what I had figured. Thanks.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
