Door panel problem
Old Feb 22, 2004 | 06:15 PM
ead94z28's Avatar
Question Door panel problem
I figured I'd throw this in and see if anyone had the same problem. Drivers side door, the outer metal seperated from the inner metal. I was going to use some liquid nail type stuff and c-clamp it and hope it holds. It seperated right by the door handle. When I pull on the handle to open it the outside metal comes apart from the inner. Any other suggestions, other than liquid nails, to bond the two metals together?
Old Feb 22, 2004 | 06:17 PM
1msfyter's Avatar
I would use something like JBweld that gets harder. Liquid nails will be flexible.
Old Feb 22, 2004 | 06:21 PM
ead94z28's Avatar
I suppose that's an autoparts store item? What's the drying time on that stuff?
Old Feb 22, 2004 | 06:24 PM
1msfyter's Avatar
Jb weld sets up in like 1 hour and turns hard in 24. Its sandable and can be drilled. It gets ROCK hard when dry. Napa, pepboys, autoZone $8
Old Feb 22, 2004 | 06:40 PM
ead94z28's Avatar
Thanks alot, I'll give it a go.
Old Feb 22, 2004 | 06:57 PM
Formula03's Avatar
Re: Door panel problem
Is your door metal or fiberglass? Anyways I had the same problem and I used the Jb weld stuff and it worked awesome.
Old Feb 22, 2004 | 07:32 PM
ead94z28's Avatar
Re: Re: Door panel problem
Panel feels like metal. I'm going to buy the stuff tomorrow and see what happens.
Old Feb 23, 2004 | 09:27 PM
Formula03's Avatar
I thought they were all fiberglass but maybe just mine are?
Old Feb 23, 2004 | 10:22 PM
The doors and door skin are SMC (sheet molded compound), pretty much like fiberglass. If you went to an auto paint supply store, they would have the proper adhesive, but I am not real sure of what part you have a problem with.
Old Feb 24, 2004 | 03:25 AM
ead94z28's Avatar
You know the rubber strip at the bottom of the window where it meets the door? When I go to opn the door, the whole outside panel comes apart and I can look down past that rubber weather stripping and see the inner door, where the window would be if it were down.
Old Feb 24, 2004 | 09:49 PM
Formula03's Avatar
Isnt that the same thing as thing as Press Molded Fiberglass, just curious.
Old Feb 24, 2004 | 09:56 PM
Could be. I'm not an expert on the subject.
cmyname1
Feb 19, 2015 08:38 PM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
MilkyClr69
Jul 29, 2002 10:01 AM
Zomie
Jul 25, 2002 07:52 AM
