Doing opti, should i do a cam too?
Old Mar 27, 2008 | 07:55 PM
  #16
mdacton's Avatar
Why not fix the opti and drive it make sure that trans is good before you open up a whole new can of worms without even knowing if the trans is right.
Old Mar 27, 2008 | 08:01 PM
  #17
SS RRR's Avatar
you're such a killjoy... even though i believe you are correct.
Old Mar 28, 2008 | 12:04 AM
  #18
dubbsix's Avatar
alot more work involed.
I would get it running first.....out of doing a cam swap...getting the water pump and opti off is the simplest part. I would wait
Thats a good point.. part of why i havent started yet. I also thought about just building a second engine when money permitted so that i could enjoy the car.. and build a more stout engine too.
Old Mar 28, 2008 | 12:08 AM
  #19
dubbsix's Avatar
Good point. I guess the more its discussed.. the more it sounds like i'll just enjoy the car as it is now.. then build a seperate motor on the side.
Old Mar 28, 2008 | 04:04 AM
  #20
Kaj's Avatar
Kaj
I've been here for awhile, kicked back and read alot, not posting a whole lot. I have a 2nd engine in the works right now that is nearly complete, it's taken two years, because of budget restraints aka the "Wife" . It's a fully forged 383 w/ gm847 cam, waiting on AI still for my Dart Pro 200cc heads and new intake. This way I can keep the original engine out of the car, if I ever decide to sell it.
It's better to start fresh, than to leave it to chance, as heavily moddifying a stock-used shortblock is not really guaranteed a proven setup, maybe for awhile, but not long. Problems will arise, and quite often at that. You're better off saving up and getting a new assembled shortblock 355/383 to put your time and money into. Aslong as it's put together right you'll have a good running, proven setup for many years.
Old Mar 28, 2008 | 07:27 AM
  #21
95firehawk's Avatar
Originally Posted by 96capricemgr
There was a timwe when I asked this same question. Now that I am MUCH more experianced I will say NO. You are going to be nowhere near close to a cam swap, a huge amount more work. I actually recommend pulling the engine entirely for a cam swap. Then again pulling the engine on my b-body may be a lot easier than an f-body.
Can you elaborate a little more on why you would recommend pulling the engine completely for a cam swap? I am not arguing your point, just curious. I am for the most part in the same boat as the OP (albeit I am replacing the opti and WP seals, removing A/C, etc.) After removing most of the accy. drive systems it doesn't seem as bad to change a cam as I feared. What else besides the intake manifold is there that would keep the OP as well as myself from doing this in the car?
Old Mar 28, 2008 | 03:44 PM
  #22
96capricemgr's Avatar
Less leaning into the car makes for more comfort, comfort means less likely to try and cut corners. Also easier to keep everything CLEAN. Allows easier removal of oilpan so you can replace the oilpump relief spring(with a GM "white high pressure) and oilpump driveshaft with a metal sleeved one, $10 worth of oiling system insurance.
Absolutely can be done in car, I have done it both ways and will never do one in car again.
Old Mar 28, 2008 | 03:46 PM
  #23
mdacton's Avatar
My knees are getting bad......cam swaps in cars are about done for me too, I think from now on they will just need to come out.
Old Mar 28, 2008 | 03:56 PM
  #24
ss.slp.ls1's Avatar
Originally Posted by Kaj
It's better to start fresh...put together right you'll have a good running, proven setup for many years.
^^^+1
^^^+1
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
nikolt1
Feb 27, 2015 09:10 PM
Injuneer
Dec 15, 2014 09:36 AM
