dogbone bent
dogbone bent
i am wondering what would cause the dogbone in the lifter valley to be bent upwards? the pushrod was snot bent at all. the rest of the dogbone fingers were fine, just the very front passenger one was bent up. does anyone have any ideas?? just trying to get some ideas before i pull the engine/heads....
I have never seen on of those bent although I change them if eng. has over 50,000mi..
I would think they would break before they would bend since they are spring steel, that's a new one to me.
new one to me too. i had some valvetrain noise and when i pulled the intake, i noticed the spider bent up, the retainer was a bit banged up, and the lifter had spun in the bore. oddly though, the pushrod was not bent. i just went out and looked at the intake port of my head and it seems like the valve guide is cracked and looks pushed upwards a bit.
re
my spider lifted up no. 3 intake arm , the lifter spun in the bore, took out my cam's surface on no.3 intake. No other real damage.
got a new cam, ordered some ls7 lifters, replaced the spider, cleaned out any metal shavings in the lifter valley, changed oil and filters a little excessively for a couple of thousand miles and have been good for over a year. I am LUCKY
CARiD
Sep 30, 2015 05:44 AM
detroitmuscle
Jul 31, 2015 04:21 AM
