Does our cars need the alternator to fire?
Old Feb 9, 2008 | 03:44 PM
95Blackhawk's Avatar
All,
Do the alternators need to be turning before our cars will fire up?
Took down my Hawk over a month ago on an opti issue. I have replace the opti and have done a complete diagnostic on the ICM, fuel pressure, and opti signal. All check out good.
I did not want to put the dampener on yet to check to see if it will fire up. However since all is checking out, it makes me think that the aternator needs to be turning for these things to fire.
This is the last thing I have before I change the computer (however, the computer checks out in all circumstances so why change).
Old Feb 9, 2008 | 03:45 PM
white97T/A's Avatar
I've started mine before with no belt on.
Old Feb 9, 2008 | 03:48 PM
white97T/A's Avatar
But as you mentioned you "took it down" over a month ago, you might need to put a battery charger on it to get it to start.
Old Feb 9, 2008 | 03:52 PM
It was charged and cranking the engine great. Do you have another suggestion? Any ideas appreciated.
Old Feb 9, 2008 | 03:57 PM
Pontiac_97's Avatar
i started mine without a alternator or belt on. i ran it for a good 1-2 minutes with the fog lights on. charge the battery and see if it fires
Old Feb 9, 2008 | 05:48 PM
94CamaroZ28's Avatar
Reseat the PCM connectors. One loose connector prevented my car from firing. even though fuel pump came on and all else looked fine. Unplugged pcm, plugged it in again, all was well.
Old Feb 9, 2008 | 06:29 PM
GreasyB's Avatar
It should be fine to fire it up without the alternator. But dont run it for too long or else you will probly ruin your battery.
Old Feb 9, 2008 | 09:29 PM
Z95m6's Avatar
You don't have a racetronix fuel pump booster setup do you? If so that wiring harness hooks directly to the back of the alternator and thats where it gets its power from. I've fought starting my car with out the alternator so I could adjust the rockers and it took me forever to figure out that it wouldn't fire because the fuel pump harness was unhooked.
Noenav
Mar 1, 2019 07:38 AM
Jazsun
Dec 29, 2014 12:14 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
