does not idle up when booster hose is disconnected
OK so I am seafoaming my motor today. I start the car and let it warm up. When warm i pulled off the brake booster line, BUT instead of idling up it about died. It idled up when the seafaom was added but when I would stop it would drop again. I got the seafaom in and reinstalled the hose and it went back to normal idle.
Why does mine not idle up like its suppose to?? I have a cam if that makes any diff.
With speed density, yeah i'd expect the idle to go up, with MAF no your idle should go down as you are almost entirely bypassing the MAF sensor, the majority of your air is not being seen by the engine and as such the engine is not injecting enough fuel.
A carb will die too. So will speed density. It has nothing to do with computer's but the internal workings of an engine.
Bottom line ya are pulling air in from the wrong place.
Speed density looks at manifold vacuum and a VE table so when the Manifold vacuum goes down it compensates automatically, MAF and Carb function much different from speed density, it definately has to do with the computer and not the engine.
If a big enough vacuum leak is created, it's not going to make any difference what type of engine management there is. No amount of compensation is going to make it run.
OK then tell me why a 1952 Chevy will do the same thing with NO computer
