does the msd box really help any?
Old Aug 27, 2007 | 03:41 PM
  #16
nicks2ndZ's Avatar
i gained 3 mpg on the highway installing a 6al on both my z's....nothing on the butt dyno....found one laying around my garage too and installed it on my second z for the 3 mpg bump
Old Aug 27, 2007 | 07:56 PM
  #17
BlackDog's Avatar
What's up with this stuff laying around the garage? I'd like to come over to your garages and rumage through a few things.
Old Aug 27, 2007 | 10:31 PM
  #18
fireman's Avatar
I have a Dig6 and I didn't feel a difference, but I didn't even feel it when my car picked up 22rwhp on the dyno.
I out an MSD6A on my old 5.0 'stang and didn't feel any difference. I took it off 6 months later and definitely felt a difference with it not on there. strange..
Old Aug 28, 2007 | 10:08 AM
  #19
Don 97 SS's Avatar
Originally Posted by shoebox
I was in the same situation-had one laying around not doing anything, so I put it on years ago. Nothing noticeable, but it can't hurt (don't let people tell you they kill optis).
I did happen to notice that one time when I was chasing an ignition problem (that turned out to be a bad plug wire), that I could notice a difference in the engine note at idle when comparing with the box or without.
Shoebox, could you further explain the "difference in the engine note at idle". Would you consider it an improvement with the box?
I agree that I doubt an MSD box wouldn't "kill" an opti, but wouldn't the fact that the ign at certain RPMS is firing multiple times and hence increasing the wear of the contact points at least marginally?
BTW, I never noticed any change with the install of my MSD Dig 6. One thing for sure, having a box tends to add one more item that needs to be checked when tracking down ign problems. Unless you have an MSD tester, and I don't, I always suspect the MSD box when encountering any ign related problem on any vehicle. As most are stating the rev limiter is far better than the oem version.
The MSD Dig6 looks good as heck parked in the engine bay.
Quickss96
Jan 29, 2016 05:56 PM
zk06
Sep 9, 2015 11:39 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
canuck94z28
Aug 19, 2015 05:50 PM
88IROC_Z
Jul 22, 2015 11:38 PM
