Does it hurt the a4 mannually shift?
Old Oct 1, 2003 | 10:29 AM
NewbieWar's Avatar
just as topic says would i be damaging it to just change gears as i would in a manual?
Old Oct 1, 2003 | 10:30 AM
BES-383's Avatar
Why would you want to?
Old Oct 1, 2003 | 10:31 AM
NewbieWar's Avatar
because of a low rpm stumble that i cant figure out
Old Oct 1, 2003 | 10:34 AM
BES-383's Avatar
No, it will not hurt your tranny.
Old Oct 1, 2003 | 10:35 AM
sszapper's Avatar
I think if all you are doing is upshifting you should be ok, but from what I understand when you start downshifting that is where you are going to run into problems.
Old Oct 1, 2003 | 10:54 AM
drewstealth's Avatar
Imo i think it does hurt the tranny. But it depends mostly on what your doing when your manually shifting. If your really getting on it i would say yeah. I would just leave it in D. In my past experiences with automatics it's not a good idea to do it all the time. Ecspecially without a good shift kit in there.
Old Oct 1, 2003 | 11:35 AM
AxeGrinder30thZ's Avatar
I do it every now and then. I never downshift manually though. Speaking of shift kits and what not, anyone know if Hurst has a dual gate shifter for Camaros. I've seen them for other cars and liked em and wanted the dual gate shift kit for my 97 Z.
Old Oct 1, 2003 | 12:03 PM
RallyRed701/2's Avatar
if you plan on racing on the road (not that i recommend it) i dont think you can beat an auto with a shift kit, downshifting manually... thats how i "get up to speed" when i need to suddenly.... i dont see how it could hurt anything. as long as im not doing it all the time, like if i was shifting it like it was a manual while i drive normal... thats gotta wear some stuff out...
Old Oct 1, 2003 | 12:41 PM
Got-LT1's Avatar
Down shifting can cause dammage if done to often, but upshifting should be okay.
Old Oct 1, 2003 | 12:52 PM
97Z-M6's Avatar
upshifting is fine never down shift.
Old Oct 1, 2003 | 02:18 PM
Jason Dove's Avatar
And if you want to know why not to downshift... it'll destroy the overrun disk (or is it called an overrun clutch, I don't recall). I downshifted lots and lost it when I had my auto. Apparently the cops in our area get thier tranny's replaced every 6 months or so because of the same problem.
Old Oct 1, 2003 | 02:50 PM
BES-383's Avatar
Why would you need to down shift? If you like shifting gears get you a manual.
Old Oct 1, 2003 | 02:54 PM
Got-LT1's Avatar
Who knows?
I do upshift at times, becasue my car dose move quicker like that. I have the 700R4, which I understand to make the deifference. I tried in my friend's 94 TA and it seemed to run slower then when you just left it in drive.
Old Oct 1, 2003 | 02:58 PM
snorkelface's Avatar
Because, sometimes you need to put the tranny in the gear you want to, and not hope it will automaically shift there. for you.
Old Oct 1, 2003 | 03:01 PM
BES-383's Avatar
4L60E will react slower when upshifting when shifting manually. I had a 700R4 allso and manually upshifted too at the track. Only because the shift points for a 700 are determined by springs in the tranny, not electronically like the 4L60.
