does a a/f guage with no 02 signal go green or red??
Subscribe
Jul 13, 2003 | 08:11 PM
This will help me determine if it's a grounding problem or a signal problem, i'm not sure. Does a a/f guage with NO SIGNAL from the 02, does it read the last green, the last red, or go blank?? I'm assuming last red since there will be no voltage. My guage is pretty much stuck on last green. Have to check the grounds too. Help me out if you can, thanks.
Reply
Jul 13, 2003 | 08:18 PM
Mine is red when the motor is off(it still has batt power)
Reply
Jul 13, 2003 | 08:30 PM
Quote:
Hmm, well i just went in the garage, turned on the ignition, engine off, A/F guage on last green, never goes red.
So it seems it's not a signal problem, i KNOW the o2 is working, i have a scanmaster hooked up to it.
How bout this question, how bout a o2 sensor with a lifted ground, all green??? If this is the fact, i know the prob. Just wanted to know wut i'm lookin at b4 i rip off my pillar, thanks again.
Reply
Jul 13, 2003 | 08:52 PM
My buddy has it in his car and it's not hooked up to the o2 and i believe it's green.
Reply
Jul 13, 2003 | 08:53 PM
Quote:
haha, ok this helps me out, it's like asking where do i go, up or down?? one guy tells me down, one guy tells me up. This helps
Reply
Jul 13, 2003 | 11:02 PM
my friend has one on his car and it stays all the way green. very rarely does the guage work. he has it hooked up but maybe something is messed up. we thought maybe he had a faulty guage but it does work sometimes. it does get annoying when you have the guage and all it does is stay on green. sorry if i didn't help answer your question.
Reply
Jul 14, 2003 | 06:37 AM
Quote:
same thing here, but mine did work for like 2 years.
Hmm, TTT
Reply
Jul 14, 2003 | 05:52 PM
TTT
Reply
Jul 15, 2003 | 12:12 AM
it almost seems as if the guage works when he put amoco fuel in his car. however, it may just be in our heads.
Reply
Jul 15, 2003 | 06:50 AM
I've got one and installed two others...my buddy's Lightning had the same problem and I just tightened up the ground and it's worked great ever since.
Reply
Subscribe
