Does EVERY head bolt pass into coolant passage?
Old Nov 21, 2004 | 06:01 PM
  #16
Dave88LX's Avatar
Re: Does EVERY head bolt pass into coolant passage?
Originally Posted by Lonnie Pavtis
You can do it 1 at a time. I've fixed other peoples installs this way.
With engine warm drain coolant. I recommend removing block plugs on both sides & radiator drain..... & waiting a few hours to allow everything to dry.
Do it right & do it once!!!!!
Remove 1 stud at a time, clean, dry & add sealer.
A little compressed air in the stud hole can help dry the block threads..... but the block plugs MUST be removed or you will create a mess with any coolant in the block. Screw stud in hand tight & torque the nut in 3 steps.
Repeat 33 more times & you're done.
Damn that sounds ugly. I pulled my drivers side valve cover off and there's coolant sitting in 3 or 4 of the little machined "eyebrows" as well as the corner of the back fo the head. I'll see if I can reach the block plug from up above, if not that's going to be a real hassle! I've got the header off though, so hopefully I can get at it.
Do I really have to have the engine warm? I'd have to hook all kinds of things back up then...can I just drain it and blow the air through? What a mess this project has become.
I've also got 3 roller tips on my rocker arms that have worn and have bronze patterns showing through. If this stupid FTP that my buddy has was working I'd upload the pics
Nate, do you remember if on yours, drivers side block plug, the motor mount bolt that goes front-to-back, did you have the bolt head? Or the protruding bolt threads sticking out that end? I've got the bolt threads, don't know if that's the problem, either way I'll try this box end wrench since my headers are off.
I hope I don't have coolant mixed in with my oil throughout the engine.
I should sit in a corner and start crying now I guess.
Old Nov 21, 2004 | 06:10 PM
  #17
nateh's Avatar
My motor mount thru-bolt runs front to rear, so the threads are at the rear of the mount. There was plenty of room to get the wrench on there. If the offset doesn't fit, try the open end. Like I said, a ratcheting box-end (Gearwrench) works wonders.
Old Nov 21, 2004 | 06:47 PM
  #18
Euclid's Avatar
Can I just do the upper bolts? I don't wanna have to take my exhaust and steering knuckle off again... :-/
Old Nov 21, 2004 | 06:51 PM
  #19
Dave88LX's Avatar
Thanks for the idea Nate, I'll give that a shot tonight probably.
Euclid, what do you mean by the "uppers", you mean just the bolts that are UNDER the valvecover inside the head? The answer to that is no...all of the external head bolts go through coolant passages too, as evidenced by the coolant running down my block. I didn't want to take my headers off either 2 hours of knucklebusting for that ordeal.
When you undo your steering, take that 'knuckle' deal, and wire brush the inside areas where they slide over the steering shaft and the rack/pinion. Clean up those same things with a wire brush as well. I had no problem putting mine back on.
I feel your pain brotha.
I take it you haven't fired it up yet?
Old Nov 22, 2004 | 08:10 PM
  #20
Jeff95TA's Avatar
Why torque it in 3 steps if only one bolt was removed at a time? I can see doing that when they're all removed to get an even loading.
Old Nov 22, 2004 | 10:26 PM
  #21
Quick96Z's Avatar
interesting..i also didnt use thread sealant. I actually just put a dab of oil on the bolt and torqued her down. It's been about a year and i havent had any problems yet.
Old Nov 22, 2004 | 10:43 PM
  #22
TCAL95Z's Avatar
Quick 96Z,
Did you use ARP studs? if not thats probably why. I called my machine shop today and asked them about this. They advised me studs leak a lot. ARP bolts don't and that they use the GM thread sealer
Old Nov 22, 2004 | 10:47 PM
  #23
Quick96Z's Avatar
ah ha, all the pieces come together. Yea, i used ARP bolts.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
