Does E.G.R./A.I.R. removal throw any codes?
Old Oct 4, 2003 | 09:27 PM
DB75's Avatar
I have a '94Z. Is this worth doing and if it is what can I expect to gain from this? Will this throw any codes? Do I need to program the PCM? Sorry about all the nagging questions. I'm just trying to get all my ducks in a row.
Old Oct 4, 2003 | 09:33 PM
You must have a good fuse in for it not to throw a code for the AIR pump after it is removed. For OBD-I, if you leave the EGR solenoid in place it probably won't throw a code. It may if you remove it. Removing either/both does not increase performance.
Old Oct 4, 2003 | 09:40 PM
DB75's Avatar
Thanks for the heads up.
Old Oct 4, 2003 | 09:42 PM
Z95m6's Avatar
you won't get a AIR code but EGR may show up every once in a while. Mine did but then i had it programmed out.
Old Oct 5, 2003 | 06:09 AM
revtime's Avatar
I removed the AIR and the EGR and no codes so far.
I took the valve off and the related hoses and put block off plates on the holes in the manifold.
No problems so far.
BigWil
Mar 29, 2015 12:24 PM
Gtpguy
Jan 26, 2015 04:50 PM
Deadbolt24
Jan 19, 2015 01:29 PM
cmdeshon
Dec 27, 2014 10:06 AM
91Bird305
Aug 5, 2002 01:39 PM
