Does A/C condenser need removed for cam install?
Old Nov 11, 2005 | 02:31 PM
psmopar's Avatar
Does A/C Condenser need removed for head /cam install? Or can The compressor lines remained hooked up and just wire compressor out of the way? I've heard most people removed the condenser but it seems some have gotten away without removing the freon or disonnecting the a/c lines.
Anyhow is it possible to do the cam swap portion or must the condenser be removed? Thanks.
Old Nov 11, 2005 | 03:02 PM
Colin91Z's Avatar
Re: Does A/C condenser need removed for cam install?
You do not need to move the compressor, but the condenser has to come out.
Old Nov 11, 2005 | 03:32 PM
97WS6SCharged's Avatar
You can tilt it up and out of the way if you're careful. I did my cam swap without discharging the AC.
Old Nov 11, 2005 | 04:07 PM
You can look at the guide on my Tech Page. I just moved the condenser out of the way. No discharging the system. You have be gentle with it.
Old Nov 11, 2005 | 10:40 PM
psmopar's Avatar
Thanks...I'll go the carefull route.
Old Nov 11, 2005 | 10:46 PM
flusz28's Avatar
guys what size bolt is on the back of the compressor that holds the metal lines? i can't seem to find anything to fit.
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
