does anyone make a piston for a 383 with low compression?
Ive been looking all over for a piston in the 8.5-9.0 range for a 383 but no one seams to make them, do I have to order a set of custom pistons or does someone make them.I really dont want to spend 800-1000 bucks like people are telling me.
Re: does anyone make a piston for a 383 with low compression?
LT1 heads are supposed to be 58cc, LT4's are supposed to be 54cc.
http://store.summitracing.com/partde...131631-8&N=120 300014
There's usually a bit of variation. Mine measured 57.something before they were milled. I just go by what GM says they're supposed to be. Anyhow, those pistons are about as dished as you're going to get with an off the shelf piston.
Like I said, there's usually some variation. I had to mill my stock heads quite a bit to make them straight after the head gasket blew. Maybe I cc'd the one on the high side. They're right around 55 now. My other set that Brent is working on started around 55 and now they're around 59 with all the porting and chamber reshaping.
Is this a thread on head cc, or pistons?
For head cc volume, do a search, this has been discussed thoroughly, in the past. Do not go by what GM states, but by what has actually been measured by those that state they have done so. You can even use 'arnie' in a search, if you like.
For pistons, do a search of the different mfrs., JE, SRP, TRW, Wiseco, Venolia, etc., etc., check their sites, and make a decision. From what I've found, a 31 cc dish is about the extent of what you may find. Crunch the #s, and if you need more volume, a bit of combustion chamber work, may be necessary.
I really didnt want to mess with the combustion chambers, but im doing a full rebuild and would like to do a 383 and I need my compression down so I can run more boost on it.
You could use the JE pistons I posted the link to above with a set of 76cc AFRs or the 64cc Trick Flow LT1 heads. That would get your compression down quite a bit.
If you are trying to lower compression with the stock heads, JE makes alot of pistons to fit your application, and you can use a thicker head gasket (.049") ? I'd also mess with the combustion chambers.
Mike
Mike
Originally Posted by Kraest
.....and you can use a thicker head gasket (.049") ?
10-31-2016 11:09 AM
