Does anyone make a 170* Thermostat?
Old Jun 3, 2008 | 08:48 PM
pelensky's Avatar
Does anyone make or a sell a 170* F (start opening temp) LT1 thermostat?
Old Jun 3, 2008 | 11:57 PM
ttop1986's Avatar
Why not the 160* thermostat? Many people run them, including myself.
Old Jun 4, 2008 | 12:03 AM
Jazsun's Avatar
If you bu ya 160 dont get it from autozone they will say its for an lt1 but its a traditional sbc one.
Old Jun 4, 2008 | 05:42 AM
pelensky's Avatar
I wanted to get a 170 as a nice compromise between the 160 and 180 so I won't have problems in the winter. Does anyone make a 170 that your aware of?
Old Jun 4, 2008 | 06:21 AM
Greaseymec's Avatar
Install a 160 stat and program your fans to come on at 170. No 170 stats around that I am aware of.
Mec
Old Jun 4, 2008 | 07:46 AM
Mec
Your fans would run all the time with that setting. Really not necessary to try to keep it that cool. The fan motors would wear out sooner and there would be more constant drag on the alternator to make the power to run them.
Old Jun 4, 2008 | 08:17 AM
97FormulaWS-6's Avatar
AFAIK there are no 170° t-stats out there for LTx motors.
Old Jun 4, 2008 | 10:40 AM
slomarao's Avatar
Not to hi jack your thread but does anyone run a thermo cooler than 160?
I use one and run one bottle of Purple Ice ( royal purple's water wetter) and my temps are still around 200-225. I would like to stay under 200 if I could.
Anyone??
Old Jun 4, 2008 | 10:47 AM
If you have a 160° thermostat, then just reprogram your fans to a cooler temperature (Mine are 170/175). That's why even with a cooler T-stat it's still getting that warm.
Old Jun 4, 2008 | 12:46 PM
Stl94LT1's Avatar
Be Cool use to make a 170* LT1 stat.
Old Jun 4, 2008 | 05:24 PM
Anyone??
Never seen one for an LT1 cooler than 160. If your running temps are that high, a cooler thermostat is not going to cure it.
Old Jun 4, 2008 | 05:34 PM
slomarao's Avatar
Any ideas on what would?
Old Jun 4, 2008 | 07:39 PM
I am not hijacking the OPs thread. A search should find you lots of suggestions.
Old Jun 4, 2008 | 07:44 PM
caldercay's Avatar
Yes, use a super-coolant, such as Purple Ice.
Old Jun 5, 2008 | 04:57 PM
pelensky's Avatar
Found 170 LT1 stat
Thank you for everyones input. Here's the deal. Be Cool use to carry a 170 deg F thermostat made by Cooper Standard. They stopped carrying them because Cooper Standard did not delivery enough on time and Be Cool stopped carrying all thermostats. I contacted Cooper Standard and they refered me to their distributor. They have then in stock so I bought a couple. I saw a picture and it is the correct dual spring with the disk.
