Does anyone know the size of the tranny line fittings?
Re: Does anyone know the size of the tranny line fittings?
OK...Just wanted to see if i should of done the same instead of using the two in series. It seems to be working fairly well for me so far though. Thanks
Brandon
Brandon
http://www.tciauto.com/tech_info/cooler_fittings.htm
1/4 " pipe thread
BTW madwolf, could you check my PM please.
1/4 " pipe thread
This is a bit old, but FWIW. I did the m6 conversion as well. I just left the cooler holes in the rad open. I did take a air nozzle and some low pressure air and blew a little out. No leaking so I must have got most of it.
Originally Posted by madwolf
Welp, that didn't work. The 1/4" pipe thread plug is too big to fit. Anyone else have an idea?
Thanks.
Thanks.
Jan 23, 2015 01:13 PM
