Does anybody have an LT1 block laying around?
Old Mar 10, 2007 | 11:37 PM
  #16
BowtieCamaro6's Avatar
sorry about the spelling errors i didnt read back over it
Old Mar 11, 2007 | 12:47 AM
  #17
turnin20s's Avatar
Aren't the gen 1 blocks and the ltx blocks completely different because of the opti at the least? I might be wrong, but thats what I thought.
Let me know if I'm wrong
Old Mar 11, 2007 | 09:45 AM
  #18
The Engineer's Avatar
The water jackets in the Gen-1 (basic SBC) and Gen-2 (LT w/ reverse coolant flow) are completely different (both block and heads). Also, the LT water pump is completey different to match the reverse coolant flow and cooling passage ways in the block (both coolant inlet an outlet on each side of the block).
WD
Old Mar 11, 2007 | 11:40 AM
  #19
aboatguy's Avatar
Originally Posted by BowtieCamaro6
i got a 4 bolt main sbc small block i was wondering if you could turn it into a lt1
It's been done with aluminum aftermarket blocks, so it can be done however, your talking many thousands of dollars in machine work for a 200 dollar block.
If you really want a conversion do a search for Jeff Green he built a monster LT1 conversion.
Here's a pict of the LTX block I'd like to own.
Old Mar 11, 2007 | 12:36 PM
  #20
95ttoplt1's Avatar
Just build the Gen 1 SBC and be done with it. You can reverse cool a SBC as well, it just takes a couple lines.
Old Mar 11, 2007 | 01:54 PM
  #21
AdioSS's Avatar
West South Central Moderator
get your own thread...
Old Mar 11, 2007 | 02:50 PM
  #22
95ttoplt1's Avatar
OK
Good luck with the conversion
D1SC383LT4
Jan 26, 2015 01:41 PM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
squinn
Aug 4, 2002 01:06 PM
