does all fbodys have the same rear carrier?
Old Jan 5, 2004 | 11:44 PM
mickeyiz28's Avatar
What is the diffrence in the carrier series in the fbodys? and how can i tell what carrier i have?
Old Jan 5, 2004 | 11:49 PM
BRIAN93Z28's Avatar
its either a 2 or a 3 series carrier, if your rearend came with 2.73s then you have the 2 series and will need to upgrade to a 3 series carrier if you plan on doing gears. If you have 3.23 or 3.42s then you will have the 3 series and will not need to upgrade. Speaking in F-body gear ratios, vettes will vary, i think they have a 2.59, and a 3.07. Anyway, you get the jist of it.
Brian
Old Jan 6, 2004 | 01:04 AM
97SS0594's Avatar
i belieive the 2002 fbodies have a diff size ring and pinion, but before that you could take the gears out of a s-10 and throw it in your camaro
Old Jan 6, 2004 | 07:15 AM
thermwood1's Avatar
Actually, you can buy 3 series gears that will work on a 2 series carrier. They just make the ring gear thicker.
Old Jan 6, 2004 | 08:10 AM
Nope, nothing specifically different about the 2002.
Old Jan 6, 2004 | 02:03 PM
mickeyiz28's Avatar
i do have the crappy 2.73s, so it will be fine buying a set of 3.42s or 3.73s to put in them without doing anything to the carrier?
Old Jan 6, 2004 | 02:05 PM
thermwood1's Avatar
Nope, you don't have to change the carrier.
FWIW, don't buy Richmond gears unless you like to hear gear whine.
Old Jan 6, 2004 | 02:56 PM
dnz28's Avatar
You will not have to change the carrier. dont listen to them people I have a brand new set of 3.42 from strange that allows you to use them in a series two. checkout thunderracing and you should find them.
Old Jan 6, 2004 | 03:01 PM
thermwood1's Avatar
Who exactly are you telling him not to listen to?
Old Jan 6, 2004 | 03:02 PM
FacelessZ's Avatar
I personally upgraded from stock 2 series carrier 2.73's to 3 series carrier 3.73's...but you can get 2 series carrier 3.73's...
Old Jan 6, 2004 | 03:06 PM
dnz28's Avatar
you people thats what I want him only to listen me, if you dont like that go hump your own rearend.
Old Jan 6, 2004 | 03:09 PM
thermwood1's Avatar
I didn't tell him anything different than you did, except which type of gears not to get.
HarleyZ28
Oct 5, 2015 06:23 AM
meissen
Jun 1, 2015 07:59 AM
blac94Z
May 4, 2015 12:11 PM
shroyvin56
Apr 3, 2015 08:15 AM
marineengineer
Feb 9, 2015 03:59 AM
