Does the AC compressor use any fluid?
Old Jan 19, 2008 | 10:57 AM
ssbowtie1's Avatar
I see fluid that looks very similar to power steering fluid around the ac compressor and coating the bottom of the pulley's and some hoses. However, I got to the power steering pump last night and really didn't see any leaks.
Is there any fluid that looks very similar to power steering fluid that is housed in the ac compressor? Also, is it common for the clutch to be very hard to turn by hand and randomly click on and off when the engine is running (If I look at the clutch I'll see it start turning for a second then stop while the engine is idling).
Old Jan 19, 2008 | 11:00 AM
mdacton's Avatar
it has oil in it
Old Jan 19, 2008 | 11:11 AM
joeSS97's Avatar
Also with the defrost on the compressor will cycle on and off.It should spin freely when the clutch is off.
Old Jan 19, 2008 | 11:38 AM
ssbowtie1's Avatar
If the oil was leaking, wouldn't that mean that the refrigerant would have leaked out too? If I have the ac on it still blows cold air. Is there a logical explanation as to why the oil would leak but the refrigerant would not escape and still cycle?
Old Jan 19, 2008 | 11:41 AM
mdacton's Avatar
put some dye in the system then check with a black light.......that will tell you.
It could just be low, or it could be oil from somewhere else
Old Jan 19, 2008 | 12:38 PM
SS RRR's Avatar
Do you see any fluid spatter on the inside of the hood?
blac94Z
Nov 4, 2015 01:59 PM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
War Engine
Sep 18, 2015 07:28 PM
