does a 94 lt1 use 3/8 or 7/16 rockers?
Old Nov 21, 2005 | 10:12 AM
sikz28's Avatar
I bought a kit from a guy on ebay and I just want to make sure the parts will work for my application. the rockers are comp pro mags 1.6 7/16 part number 1305-16. Can anyone verify that these are a direct bolt on or will I need to change anything else to use them. He also included guide plates, are these rockers self or nonself aligning? And are the guide plates all I need to install if they are nonself aligning?
Thanks for any help
Old Nov 21, 2005 | 10:25 AM
Crazy95Z's Avatar
Re: does a 94 lt1 use 3/8 or 7/16 rockers?
They are NSA Rockers, however they have a 7/16th stud. From the factory, our cars come with screwed in 3/8th studs. So if they don't include need studs, then you also need to buy a set of 7/16th studs. You can pick them up pretty cheap and they are stronger than a 3/8th stud. That's all you'd need, just remember to install the guideplates when you change the studs.
Old Nov 21, 2005 | 10:27 AM
sssalah's Avatar
Small blocks came with 3/8" rocker arm studs, the 7/16" is an upgrade and all thats needed to run them are 7/16" studs, you can get the ARP for ~$35. The guideplates are needed because these rockers are NSA.
Old Nov 21, 2005 | 10:29 AM
sikz28's Avatar
thats what I needed to know.
thanks for the quick replies.
Old Nov 21, 2005 | 06:34 PM
94 TA TT2S's Avatar
Are they GM guideplates????
Old Nov 21, 2005 | 06:35 PM
kingman109's Avatar
also ur gonna need hardened pushrods with those guideplates
[ unless 94 was the year they came........ not sure ]
also ur gonna need to clearance your valve covers - so rather than guess and check - here this will help http://www.hotss.com/Members/scott_vaca/pro-mag.htm
Old Nov 21, 2005 | 06:38 PM
12sec94z28's Avatar
yes 94 was the year they came with hardened pushrods.
Old Nov 21, 2005 | 06:40 PM
94 TA TT2S's Avatar
I concur
Noer
Feb 28, 2015 11:29 AM
alphaauto
Jan 23, 2015 07:42 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
