Do you need a X-PIPE on true dual?
Old Jun 25, 2003 | 06:31 PM
pelebkf's Avatar
Question Do you need a X-PIPE on true dual?
I am looking at putting a true dual exhaust on a 95z. Using Hooker LT's do you really need a x-pipe or can you go strait back from the headers. And what is the bext x-pipe to use if that is nessesary?
Old Jun 25, 2003 | 06:34 PM
FacelessZ's Avatar
No you can use a Y-pipe...
Old Jun 25, 2003 | 06:43 PM
mojo's Avatar
If you are going true duals-you don't need an X pipe or H pipe-they do help the scavanging of the exhaust though.
Old Jun 25, 2003 | 06:47 PM
FacelessZ's Avatar
a Y has been used many times on true duals...
Old Jun 25, 2003 | 06:51 PM
revtime's Avatar
A true dual exhaust is just that DUAL, meaning 2. A Ypipe is 2 pipes going into one pipe therefore it would not be a true dual setup.
Old Jun 25, 2003 | 06:58 PM
FacelessZ's Avatar
In that case a true dual using an x-pipe isnt TRULY dual then because its not 2 individual pipes going back from the headers...
Old Jun 25, 2003 | 07:00 PM
pelebkf's Avatar
http://www.american-muffler.com/item1.asp?Cat_ID=1
This is a site that I came across. Is this a good buy on a x-pipe and what are the dimensions that you need on this to accoplish a dual setup on a 95z.
Old Jun 25, 2003 | 07:07 PM
superal's Avatar
Please think before you type...
Old Jun 25, 2003 | 07:10 PM
KY95Z28's Avatar
As said above you need either an H-pipe or X-pipe....the x seems to be the most popular and easiest to do. There are all kinds of x-pipes, but on my car I just called up Summit and asked them what the had.....got on for like 40 bucks and it is similar to the Dr. Gas, just not as neat and clean. (Flowtech )
Any how check out my website pg 6 for pics and list of parts w/ prices.
http://camaroz28.cardomain.com/id/ultraz28ky
Nick
Old Jun 25, 2003 | 07:16 PM
pelebkf's Avatar
Does that price include the pipes coming off the X ???
Old Jun 25, 2003 | 07:22 PM
KY95Z28's Avatar
No it's just the x-pipe section, I had the shop that did mine do the pipe....The do sell kits with the pipe(Heddman I believe and some other high priced units). Just buy the parts and have a shop bend the pipe and weld it up, it'll be the cheapest and easiest way. Not to mention you may run into problems with fitment etc. with the prefabbed pipes.
Nick
Old Jun 25, 2003 | 07:28 PM
pelebkf's Avatar
I hate to ask this but between the dynomax mufflers and the spiral flow mufflers which one would be "quieter"?
Old Jun 25, 2003 | 07:34 PM
revtime's Avatar
Faceless, an H pipe connects the pipes together as well but it still has an exhaust pipe running on each side of the car, true duals.
I am not trying to be a **** but this is the second time I have seen you give wrong advice. Alot of newer guys come on here looking for advice and they take it as fact that what they read here is good, so please if you have personal expierence with the subject matter then by all means chime in. If not then let someone who does know answer the question.
I am not perfect, but you will notice that I stay out of the cam and inner engine tech questions cause I really don,t know that much about it, never had my motor opened up so I let the guys who have done it answer those questions.
I just don,t want to see someone screw their car up cause you gave em bad advice.
Old Jun 25, 2003 | 08:10 PM
kmook's Avatar
Advanced Tech Moderator
Old Jun 25, 2003 | 08:13 PM
FacelessZ's Avatar
I apologize all. Sometimes I get caught up in my own typing...I'll sit back and read more before I respond...
My bad...
